Old 04-26-2014, 06:27 PM   #1
dman1982
dman1982's Avatar
drive shaft question
so i think my driveshaft is bent, a u-joint cap popped out while driving and the driveshaft hit the deck....limped it home...fixed the u-joints, drove it a couple days later and had a weird vibration at 50 mph or so, so i got the tires balanced and it help a little bit but not all the way...now there is a little annoying vibration in the truck at highway speeds...
my question is...i came across a aluminum driveshaft that is the same length as my current driveshaft, should i use a aluminum driveshaft in a 84 k10 with a 5.3? will it hold up?
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
Old 04-26-2014, 06:27 PM   #2
dman1982
dman1982's Avatar
Re: drive shaft question
as long as the ujoints work...
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-26-2014, 06:49 PM   #3
79Betty
79Betty's Avatar
Every new vehicle even the newer 1 tons n such have aluminum shafts. Truck your 5.3 come from had one so i don't see why not so long as the u-joints are right.
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 04-26-2014, 06:50 PM   #4
dman1982
dman1982's Avatar
thats what i was thinking...but wanted to check before i dropped money into something that isn't going to hold
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
