Old 04-27-2014, 10:10 AM   #1
Houston Ben
Houston Ben's Avatar
High mount sanden 508 fittings
Hi All,
There seems to be a lot of options for fittings for the sanden compressor, some cheap and some expensive. I was wondering which fittings everyone has used to connect the hoses to the compressor on a squarebody truck?
Thanks for any help.
Houston Ben is offline   Reply With Quote
Old 04-27-2014, 10:53 AM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: High mount sanden 508 fittings
Just go by a AC shop and let them make them up for you.That's what I did, they charged me like $25.00 to do them.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-27-2014, 01:12 PM   #3
solidaxel
solidaxel's Avatar
78 evap. and 78 condenser new hose and fittings for the Sanden
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-28-2014, 03:11 PM   #4
Houston Ben
Thanks for the replies guys, just wasn't sure if I had to supply the fitting or if the A/C shop would have them on hand. Now I have to find an AC shop.
Ben
Old 04-28-2014, 03:24 PM   #5
solidaxel
solidaxel's Avatar
My A/C shop in Tucson, Century Auto Air conditioning has all the fittings and he had to fab two of them so I could use my existing parts. Air blows cold 20* but summer has not arrived yet!
LS 3 4L70E
Old 04-28-2014, 06:06 PM   #6
Andy4639
Old member
Andy4639's Avatar
Question Re: High mount sanden 508 fittings
20*!!!
How does it keep from freezing up? 32* it will start freezing up and locking down the compressor.
Old 04-29-2014, 04:51 PM   #7
Houston Ben
Question, is it fine to put the compressor on with belt and drive to ac shop without it hooked up? Also, I ordered a Vintage Air 04808-VMA from summit which is a sanden 508 style it this going to work? I thought it was an actual sanden compressor until after I ordered it and I just want to make sure it is a good brand.
I no nothing about AC....
Old 04-29-2014, 05:32 PM   #8
solidaxel
solidaxel's Avatar
DO NOT hook the power 12VDC to the compressor wire, and it will be OK.
When it starts to get real cold I blend the heat control or turn it off!
I am waiting for next month and all of June when it is over 100* it will never get that cold in a black truck!
LS 3 4L70E
Old 04-29-2014, 06:11 PM   #9
Andy4639
Old member
Andy4639's Avatar
Cool Re: High mount sanden 508 fittings
As long as you don't power the clutch it's fine. Hook everything up but don't power the clutch with the fan switch.
As far as it being a good brand I can't say but if it's a sanden brand it should be fine.
Old 04-29-2014, 07:04 PM   #10
Houston Ben
Thanks guys, much appreciated. Is the vintage air compressor a good one?
Old 04-29-2014, 10:01 PM   #11
Houston Ben
Found a little mor on vintage and seems to have a good rep
Old 04-29-2014, 11:00 PM   #12
Andy4639
Old member
Andy4639's Avatar
I used Classic air before the LSx motor swap and was very happy with it.
http://www.classicautoair.com/67_72_..._Chevy_AC.html
