Old 04-27-2014, 11:03 AM   #1
53farm
axle over spring on '53 3600 frame?
Is anyone running a rear axle flip (spring-under-axle) on a 1947-1954 Chevy 3600 WITHOUT a frame notch?
I have a rear axle out of a 90's blazer that I want to install on top of the leaf springs to drop the rear down a bit. I know the perches will have to be changed. I also know notching is ideal for max travel but not sure I'm at the point of wanting to cut the frame. Not looking to lay the frame on the ground obviously, but hoping to do a 4" dropped axle in the front and would like the rear to end up about the same height as the front. From what I understand, the 3100 frames have a taller arch in the rear than the 3600 frames, and wondered if anyone is running the spring-under-axle configuration with no notch on a 3600 truck? If so, does it still have a reasonable amount of suspension travel? Truck will be a driver/cruiser/occasional mild hauling. Thanks.
53farm is offline   Reply With Quote
Old 04-27-2014, 12:55 PM   #2
_Ogre
_Ogre's Avatar
Re: axle over spring on '53 3600 frame?
i thought the ad trucks already ran the axle on top of the springs.
shop air compressor timer
Old 04-27-2014, 12:59 PM   #3
53farm
The 1/2 tons are indeed spring under axle, but the 3/4 and 1 ton truck are spring over axle in stock form. Was doing some more searching, looks like flipping the rear shackles upside down may be a possibility, but still curious to hear from anyone running their rear axle on top of the springs on a 3/4 ton 3600 truck.
Old 04-27-2014, 01:05 PM   #4
Hogger54
Hogger54's Avatar
I don't think your going to have much room without a notch. I pulled 3 leafs, and put a mustang axle in. I'm at 4" from the bump stops with the axle below the springs.
Hogger54 is offline   Reply With Quote
Old 04-27-2014, 02:52 PM   #5
Hampshire
Hampshire's Avatar
If you flip the axle to the top, you have 3" or less - not enough. I'm doing a 2" notch on my 3600 in the next week or so. I've already removed some leaves and will be doing a couple other tweaks. Definately easier to lower a 1/2 ton.
Hampshire is offline   Reply With Quote
Old 04-27-2014, 03:15 PM   #6
OrrieG
OrrieG's Avatar
this might help a little, show stock relationships
http://chevy.oldcarmanualproject.com...esto/53134.htm
OrrieG is offline   Reply With Quote
Old 04-27-2014, 04:52 PM   #7
mr48chev
mr48chev's Avatar
I'd think you will need at least a 2 inch notch if you flip the axle just for movement clearance even if you never carry a load in it.
Flipping the rear shackle even if it will flip will throw your pinion angle off a bit at best and I'd imagine that raising the spring hangers to lower the rear is far more work than putting the axle on top of the spring and putting a mild notch in and boxing that section of the frame.
My ongoing truck projects:
Old 05-01-2014, 10:51 PM   #8
Coach529
Coach529's Avatar
Here is a picture of a axle flipped and a notch on a 3600 frame.
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 05-02-2014, 05:27 PM   #9
53farm
Thanks for the replies folks!
Old 06-02-2014, 05:35 PM   #10
2or4wheels
I didn't want to cut on my frame either, but ended up doing it. A buddy of mine came over to do the welding as I didn't quite have the confidence to make good welds on something so critical. Picture attached. Have a Camaro/T.A. rear under it now, removed 2 leafs. There was another guy on a different forum that put a Progressive kit under his 3600 (http://www.progressiveautomotive.com...uspension.html). I didnt go this route, because it seemed that the leaf packs would be sitting too close together for our ~40" frame width. But it appears it can be done.
2or4wheels is offline   Reply With Quote
Old 06-03-2014, 01:01 PM   #11
DaveCt
DaveCt's Avatar
I just completed my notches this past weekend.
DaveCt is offline   Reply With Quote
Old 06-03-2014, 01:04 PM   #12
Coach529
Coach529's Avatar
Looks great!!
1949 Chevy 3600
Old 06-04-2014, 07:15 AM   #13
DaveCt
DaveCt's Avatar
Originally Posted by Coach529 View Post
Looks great!!
Thanks Coach. Your build thread was an inspiration, thanks.
Old 01-09-2015, 08:37 AM   #14
1948GMC
1948GMC's Avatar
Ya notching works best I am going to have to do that to my 3/4
1948GMC is offline   Reply With Quote
