Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 04-27-2014, 09:02 PM   #1
Sillyoldman
#16876
Sillyoldman's Avatar
Compressor wirng
I have an electrician here wiring my shop with extra outlets, Heat and a future compressor. I'm wiring for a 240v compressor. The electrician wants to know if I want an outlet or a hard wired switch. I really do not know. I'm thinking a twist outlet. Any advice?
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 04-27-2014, 10:51 PM   #2
truckdude239
truckdude239's Avatar
Re: Compressor wirng
Do an outlet but have a switch put inline so you can turn it on and off
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 04-28-2014, 06:52 PM   #3
Sillyoldman
#16876
Sounds good. I was leaning Twist plug but both would be a better option. Do most 240 compressors come with a male plug or for hard wire?
Old 04-28-2014, 07:03 PM   #4
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Depending on the Amperage and Voltage you can use a Nema L5-30 or L6-30 twist lock plug and outlet.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 04-29-2014, 01:03 PM   #5
truckdude239
Mostvare set up for hard wire
David fuller
2000 Tahoe 5.3l 378
Old 04-29-2014, 06:55 PM   #6
_Ogre
_Ogre's Avatar
your electrician means you need a means of disconnecting the power by code
you can hard wire it if you have line of sight to the electrical panel
either will work; a switch or a plug. the plug will be %10 the cost of the switch.
if you go with a plug buy both the outlet and the plug at the same time
shop air compressor timer
Old 05-04-2014, 11:24 AM   #7
truckdude239
other great thing about plug is if you ever get a big welder you can unplug compressor and plug in welder
David fuller
2000 Tahoe 5.3l 378
Old 05-04-2014, 11:38 AM   #8
69chevytrucker
69chevytrucker's Avatar
plug is the best way if you ever have a issue with the compressor you dont need to hire a sparky to come unplug it
69chevytrucker is offline   Reply With Quote
