AAW highway series routing info
Just curious who has put a non factory wiring harness in and how they routed it. Looking for a few pics if possible. And where you mounted the bulkhead. I will have a smooth firewall with no holes except for throttle cable and maybe a few others.
Re: AAW highway series routing info
Anyone????
I just installed the highway 22 kit and really liked it. Every thing was labeled and very clear instructions. I probably could have used the 15 but it is nice to have extra circuits for the future.
![]() Join Date: Feb 2001
Ttt
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
Here is the bracket I made. It holds my ecu on the top as well.
[QUOTE=Sean1985;6653073]Where did you come through the firewall? I want to try to keep it as low and hidden as
I actually went through the holes under the seat where I believe the factory gas lines ran. I have a separate harness for the motor and that I ran behind the motor. You can see the harness behind the pass valve cover. I'm pretty ocd my self when it comes to hiding wires. |
Cool. Thanks for the info.
Steller wiring man!!! Do you have a template for that bracket?
1969 ![]() 2015 GMC 2500 Duramax (Daily Driver) 1999 Jeep TJ 2010 Harley Street Glide Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981 |
Thank you. I don't have a template sorry. Here is a better picture of how I ran the chassis
wiring. It is in 1/2 loom and fits nice and tight against the trans tunnel. When the carpet and pad is down you will never know it's there. |
