04-28-2014, 02:43 PM | #1 |
Wiper motor wires? Black single wire. Help
Ok so my wipers were not working when I got the truck. After doing some research and some understanding of the wiring i tore into it. My switch is a three position switch which can be depressed for the squirter, I can hear the relay close but no squirt. Thats not the question though.
My question is do I have a single speed motor? It has a yellow wire which is constant hot that jumps from the relay to the motor terminal. And a blue wire beside it which is the ground from the switch. my other question is whats the black wires purpose coming from the motor? I understand it is the ground feed for the switch but it was not grounded internally. so nothing would work but the squirt relay. In other words I removed that ground wire from the motor and made a good positive under dash ground and the wipers now work. But they only have one speed in either position. Hows the wipers suppose to work on these trucks! |
04-28-2014, 03:02 PM | #2 |
Msgt USAF Ret
Re: Wiper motor wires? Black single wire. Help
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
