Old 04-28-2014, 02:44 PM   #1
WATSON403
pulling 292 need help asap
Ok so I need to lift up my motor to drop the oil pan because the oil pressure relief valve is stuck closed I've unbolted. The motor mounts andnothing just wondering if anyone has any info on the subject
WATSON403 is offline   Reply With Quote
Old 04-28-2014, 03:05 PM   #2
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: pulling 292 need help asap
You can only lift the engine about 2 inches without having to unbolt the rear mounts. Also you have to bring the number 1 cylinder to TDC so the front of the pan will clear the crank and connecting rod. Talk with Sharps40(Rich)..he'll be able to tell ya quite a bit on the subject. By the way..did you call?
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 04-28-2014, 03:05 PM   #3
padresag
did you undo the rear ones to?
ron
padresag is offline   Reply With Quote
Old 04-28-2014, 03:10 PM   #4
WATSON403
ok ya I tried calling and I did undo the rear mounts and nothing I try lifting the motor and the trucks front end is lifting almost
Old 04-28-2014, 03:11 PM   #5
1963c-10
1963c-10's Avatar
If the front and rear mounts are disconnected, there shouldn't be anything but clutch linkage that could hold you up.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-28-2014, 03:12 PM   #6
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Let me search out Sharps's thread and I'll post it here.
Old 04-28-2014, 03:16 PM   #7
WATSON403
Ya I'm getting outta Dodge right now the weather is taking a turn for the worst but I should be back at it later today
Old 04-28-2014, 03:19 PM   #8
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Here ya go http://67-72chevytrucks.com/vboard/s...d.php?t=626090
Old 04-28-2014, 03:46 PM   #9
WATSON403
I undid the clutch linkage I know I shoulda got some pics but it looks like tranny is almost touching the bottom of the cab already like there's a spacer inbetween this is a c20 also if that makes a differance?
Old 04-28-2014, 03:53 PM   #10
WATSON403
Thanks tj I'm pretty sure I know what I gotta do now also I'm just gunna hook those rear mounts back up cause like he said its gunna be a wiggle festival getting them back in
Old 04-28-2014, 04:16 PM   #11
Wrenchbender Ret
Watch the fan blades don't hit the radiator.
Wrenchbender Ret is offline   Reply With Quote
Old 04-28-2014, 05:44 PM   #12
WATSON403
Originally Posted by Sharps40 View Post
Rear mount bolts is an everlovin teatotallin boogereatin wife'll wash yer mouth out wif Lysol PITA!
Ya they were pretty easy to get off but as I was taking them off i was thinking this isn't gunna be fun puttin these back
Old 04-29-2014, 11:49 AM   #13
padresag
they all go back in relatively easy if one knows what they are doing. look at it ; realize how it goes together; what sort of shape are the mounts in. are the collapsed or falling apart and you are putting them back in that way. collapsed mounts change the relationship on how the thing bolts together if you have the engine weight sitting on the mount. the height of a new insulator will change the angle of the bolt in relation ship to the hole in the b/housing
ron
Old 04-29-2014, 07:39 PM   #14
WATSON403
Ya I ended up having to pull the rear mounts should be fun putting them back in
Old 04-29-2014, 08:08 PM   #15
padresag
on all of your mounts just have the bolts in by finger , don't tighten until you have them all started so if you have to adj the engine a hair , you can. rear mounts just have the bellhousing close without weight on the insulator so the if you have to move the engine a bit , so it is easy to do. do not tighten one side and then try and install the other side. start the bolts in the frt mounts first
ron
Old 04-29-2014, 08:45 PM   #16
WATSON403
ron
Thanks man ill keep that in mind any advice to make this run smoother is very welcome
