Old 07-30-2003, 01:07 AM   #1
nrgflow
Should the clutch mechanism on a 4 speed look like this?
I have a question regarding the clutch mechanism which connects to a 4 speed tranny on an 82 inline 6 engine. Should the rod (circled in yellow) run parallel to the bar located to the right of the red line and not at an angle as displayed in the picture? For some reason it seems like the mechanism is kinked. Any insight will be greatly appreciated.
Will
82 Chevy Truck LB
292 inline 6
4 spd granny
nrgflow is offline   Reply With Quote
Old 07-30-2003, 12:22 PM   #2
PHOENIX
That doesnt look right to me.
I will check mine at lunch and post again.
It almost looked like your fork is too far towards the engine.
Ill post after I look at mine.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 07-30-2003, 12:33 PM   #3
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
It looks normal to me, it won't be perfectly parallel. What makes you question it?
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 07-30-2003, 01:09 PM   #4
nrgflow
Well the point that connects from the fork to the clutch pedal assembly (located under the red line) looks like it is not connecting correctly as it might cause unneeded stress. It appears like Phoenix said the fork is either too far towards the tranny side or the clutch mechanism rod needs to move over towards the tranny side. But the part of the rod that connects to the clutch pedal seems fine.
Will
82 Chevy Truck LB
292 inline 6
4 spd granny
Old 07-30-2003, 03:36 PM   #5
PHOENIX
My z-bar seems to be closer to the bell housing then yours.
The adjustable bar is at a slight angle, but not as much as yours, thats because my z-bar is over further. The clutch fork does look about right though, mine looked further forward then I thought it was. I remember last time I change my clutch I played around with the z-bar. I was able to slide it around and get it to stay where I thought it was best. No linkage problems so far.
Old 07-30-2003, 05:13 PM   #6
nrgflow
Do you have any spacers in your z bar which moves the bar closer to the bell housing? Mines have a couple but I don't think the bar can move any closer to the bell housing since the clutch pedal that is attached to the z bar is already pretty tight. Only other thought is that the clutch fork is the wrong one maybe? Do they make different lengths?
By the way thanks you all your insight.
Will
82 Chevy Truck LB
292 inline 6
4 spd granny
