View Poll Results: Which is better
200r4 13 40.63%
700r4 19 59.38%
Voters: 32. You may not vote on this poll
Old 07-30-2003, 04:55 AM   #1
Iceman7642
P!$$ on Ford
Iceman7642's Avatar
200r4 vs. 700r4
which is better for quality and speed and stuff
i won't be towing, have an occational haul of stuff but not heavy
i need better gas mileage (lower rpm at highway)
and i want to go faster and get there quicker
i have a th-350 so i have the length for the 200r4 andthe mounts for the 700r4
i also want to get the front and rear end out of a c-10, my uncle got a c-10 for free and i'm gonna ask him if i can swap. shoun't that ring and pinion have a lower ratio, cause im sure my c-20 has a ratio for more torque (im guessing)
[FONT="Impact"][COLOR="Navy"]Michael
Lowered 1972 C-20 Longbed with 350 and TH350
1995 Tahoe LS - Custom intake, k&n, TBI spacer, sweet tail lights, clear front lights...
2009 Nissan Versa
I am 26, married, and we had our first baby in July of 2009
Iceman7642 is offline   Reply With Quote
Old 07-30-2003, 05:37 AM   #2
73stepside
73stepside's Avatar
i didn't vote, but both have strong points and weak points. 200 if you want easy install. 700 if you want to find one quickly
04 GMC Sierra RCSS
70 CST LWB
04 HD Sportster 1200 Custom
73stepside is offline   Reply With Quote
Old 07-30-2003, 09:46 AM   #3
sniper2321
sniper2321's Avatar
iceman there are 2 board members that have them in there trucks and an old post about this say 2 or 3 weeks ago. the 200 was a 3 speed that had a bad pump then they redesigned it with overdrive. it has a better 1-2 gear then the 700r4 plus they have problems with burning up the aluminum drum from the band engagement but mosst good trans guy know how to make both of these trans work real good. check out the link www.ptsnctb.com they make custom parts for the 2004r to with stand 850 turbo h.p.
sniper2321 is offline   Reply With Quote
Old 07-30-2003, 01:19 PM   #4
Project1970
14.1 @ 96MPH
Project1970's Avatar
It's six of one and a half dozen of the other. I voted 700R4 because that's what I've got.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 07-30-2003, 04:28 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I say 200 4R. The one - two shift doesn't bog your motor, and they are plentyfull at any junkyard, actually easier to find than the 700.
Old 08-01-2003, 01:43 PM   #6
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
Put me in the 200R4 box. Have one in my 66.panel with 3.07 rear end, 350 engine, real nice.
Nevada City, CA
Everett, Washington
57 3/4 rat, 235, 3spd
66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring
68 C10 LWB 350 4spd, 4.56 rear dump runner
82 Camaro, 305, THM-200-R4
84 Monte Carlo 305 TH350, land tuna
85 Tercel SW, snow runner
DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB
TERRYP is offline   Reply With Quote
Old 08-01-2003, 02:17 PM   #7
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
i like my 700r4. it shifts like a champ & hop-up/rebuild parts are more common. I dont find the 1-2 shift bogs my motor because I'm running a 2.56 rear end so that low firstgear is all that saves me from being a slug. I'm using the painlesswireing lock-up kit & I've put a B&M shift kit, a highpressure valve, and a corvette 4th gear kickdown valve. The guys are right that a 200 is an easier install but not a huge amount. You can tow with the 700 but they say in third gear. I havnt towed yet but i'd tow on flat ground with a big cooler & a light trailer/load. PM me if ya wanna know more. Good luck
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 08-01-2003, 04:51 PM   #8
lukecp
Formerly yellow72custom
lukecp's Avatar
I am going to go with a 200R4 whenever i swap out my Th350 for an OD (several years in the future). Dosent the 200R4 also allow full-throttle upshifts to OD, while the 700R4 dosent?
I think i will be real happy with a 200R4 and 3.42 gears compared to my current Th350 and 3.07 gears
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 08-01-2003, 09:31 PM   #9
Iceman7642
P!$$ on Ford
Iceman7642's Avatar
thanks for confusing me even more guys!!!
Just kidding, but I am still split on which one to go to, i think i'll ask my uncle cause his friend works in a tranny shop, and if anyone he would be the one revuilding it for me cause I know jack $hizzle about trannys, hey but the tranny guy's name is jack.
thanks all
2009 Nissan Versa
Old 08-01-2003, 09:35 PM   #10
Jwill41
Jwill41's Avatar
is it 200r4 or 2004r ??
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 08-01-2003, 09:48 PM   #11
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
It is 200-4r
A 700 will allow full throttle upshifts in OD if you install a Corvette servo. Real common mod. Almost any properly built up 700 will have it done to it.
Old 08-02-2003, 03:13 AM   #12
Injected68LS1
Injected68LS1's Avatar
I vote for the 700r4. I have one from Bowtie Overdrives and I love it. The install was easy. They sell a TV kit that lets you adjust shift points and how hard the shifts are. Mine has a 1 year, unlimited mile warranty. Price really isn't that bad either. Check out www.700r4.com. I have the Stage 3, 2200 torque converter and TV system. The Stage 3 is good for 600 horsepower they say. My only advice is to get a really big RV heat exchanger.
Also if your motor bogs get some more HP.
1968 Chev SWB with 1998 Corvette LS1
305hp and 320 ftlb to the wheels (stock engine!)
AEM EMS and wideband O2 sensors
Bowtie Overdrive's 700R4, stage 3
Baer 4 wheel discs and 20s
http://iciclelanding.com/aperture?album=2049&view=album
Injected68LS1 is offline   Reply With Quote
Old 08-03-2003, 07:56 PM   #13
86k10
Quite a poll going on here but being a trans tech myself, I just look at it like this. How many trucks have any of you guys seen factory equipped with 200's, hmm, and besides don't let anyone kid you the 700 is a tougher tranny if it's built right. Just my humble 2 cents.
98 Neon
97 Grand Prix GT
02 Grand Prix 40th Anniv.
86 GMC 5.0
77 Olds 98 6.6
REAL AMERICANS, DRIVE AMERICAN
86k10 is offline   Reply With Quote
