Old 07-30-2003, 08:56 AM   #1
foxyjoe
Rocker panels
Any tips on removing rocker panels in preparation of replacing them?
foxyjoe is offline   Reply With Quote
Old 07-30-2003, 09:47 AM   #2
dubie
dubie's Avatar
I just layed the new one over the existing one , traced the line and cut it out with a grinder and cutting disc.
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 07-30-2003, 10:50 AM   #3
sweet n rare67
Young truck fanatic
sweet n rare67's Avatar
just started to do my floor and rockers last weekend and when i had about half of the floor cut out i just checked how much it was going to cover. then i ground out the welds, got the floor back in place and tacked it in place. it is harder than is sounds though.
Good luck
sweet n rare67 is offline   Reply With Quote
Old 08-02-2003, 01:27 PM   #4
foxyjoe
I started to drill out the spot welds, which is a clean way but can be time consuming! Anyone try this? I don't know if will work alng the floor pan though.
Old 08-02-2003, 01:53 PM   #5
Southpa
Southpa's Avatar
The hard part is locating the spot welds. Your old rocker is trash anyway, right? So it won't hurt to use a little well-placed force and leverage here and there. Take a sharp edged prybar and start tearing it out. When you locate a spot weld don't pull any further, you will rip the metal underneath, you want to keep that. Drill out the top layer of metal, pry again and it should pop off. Then continue until you find the next spot weld. I've heard some people raving about spot weld cutting bits. I priced them out and found that they weren't, aren't and won't be used by me.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 08-02-2003, 02:11 PM   #6
foxyjoe
Thanks for the tip!
A friend gave me some of the spot weld cutters you mention. They work well, but the spot weld on the truck are so small in diameter that a 1/8" drill works fine.
See ya!
