04-30-2014, 01:34 AM | #1 |
Need a bigger alternator
I need a 100 amp alternator, I was wondering if I can use a alternator from a later 70s or even 80s truck because some of the 454 models had bigger alternator. I currently have a 60 amp and it doesn't keep up with my electric fans. My truck has a 402 big block. Do the newer model alternators bolt the same way my does? I thought I've seen this before on this forum.
343 NEVER FORGET 9-11 FIGHT ON!!! GO USC!!! PROUD OWNER OF A 1970 1/2 TON |
04-30-2014, 02:09 AM | #2 |
Re: Need a bigger alternator
Powermaster made me a 225amp alternator for my LS project. They can probably provide you with what you need.
04-30-2014, 06:56 AM | #3 |
I went straight from the stock, externally regulated alternator to a CS144 (from a 1994 Chevy Caprice with the police package). It bolted into the same location without any modifications. I did have to modify the wiring a little, but that was it.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
04-30-2014, 08:50 AM | #4 |
I use a Powermaster 140 amp GM 12si style alt I got flebay a few years ago. In my truck I run two air compressors and a small amp. Alt. works great and I've had no issues in the past 2 years.
04-30-2014, 11:13 AM | #5 |
Thanks for the suggestions!
04-30-2014, 11:15 AM | #6 |
Moderator
Powermaster. Made here and excellent technical support.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
04-30-2014, 05:15 PM | #7 |
Another vote for CS144. They last long and have good idle amperage, which is important for electric fans.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
04-30-2014, 11:00 PM | #8 |
Do they have a external regulator or internal regulator?
04-30-2014, 11:01 PM | #9 |
Check out their website, they have all kinds.
04-30-2014, 11:26 PM | #10 |
