Old 04-30-2014, 11:58 AM   #1
KMC3420
KMC3420's Avatar
What year 5.3?
I have been doing lots of research on swapping a 5.3 into my 72. I am going to get my engine from the local salvage yard. I am needing info on what is the best year(s) of the 5.3 that I should have them look for? I understand the DBW vs DBC, DBC seems to be what most guys have. So what year should I have them look for, and what is considered low mileage on a 5.3 as I have never owned one? I have already purchased dirty dingo sliders, as well as the CPP sheet metal perches. Thanks for any info.
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 04-30-2014, 02:02 PM   #2
dman1982
dman1982's Avatar
Re: What year 5.3?
i got a 2004 5.3 with the dbw, i like it, its responsive, but I'm having a hard time getting use to it...i have a lot more power now and not used to it...its pretty sensitive, i know on the 04 (mine anyways) it has the returnless fuel system and its pretty easy to install
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
Old 04-30-2014, 02:17 PM   #3
KMC3420
KMC3420's Avatar
Re: What year 5.3?
That is the info I am looking for and should have put more info in regards to the fuel system and which years would be the easiest to install. The guy who I am having find the motor for me asked me what year I wanted. Just needing some info to give to him. I didn't know as well if there were any problem years to avoid. Thanks for the reply. I looked through your swap thread, looks like you did a good job and pretty straight forward. All the extras you have to buy seem to add up.
Keagan
Old 04-30-2014, 02:31 PM   #4
dman1982
dman1982's Avatar
Re: What year 5.3?
I found mine and was somewhat of a good deal for the motor and tranny, 130k for 1200 bucks with the harness, your doing it right by researching, I just found mine and got lucky, it's been a fun project tho
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-30-2014, 02:34 PM   #5
KMC3420
KMC3420's Avatar
Re: What year 5.3?
Thanks for your help, just trying to avoid any problems up front. Sounds like you got a pretty good deal. I am looking for the motor and tranny combo, just to make things easier. I have read aliens thread about LS engine swap info, it has helped out a ton.
Keagan
Old 04-30-2014, 02:36 PM   #6
dman1982
dman1982's Avatar
Re: What year 5.3?
Ya no problem, if it wasn't for this site I'd of sold my truck 4 years ago lol
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-30-2014, 02:36 PM   #7
KMC3420
KMC3420's Avatar
Re: What year 5.3?
I have a 79 K10, short wide. Pretty similar to yours, redid it when I was 16 with my dad, its due for another redo. Probably will throw an 5.3 or 6.0 in it when the time comes. I imagine the 5.3 makes some good power over my old 350.
Keagan
Old 04-30-2014, 02:38 PM   #8
dman1982
dman1982's Avatar
Re: What year 5.3?
Unbelievable difference!!! Love it so far
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-30-2014, 03:28 PM   #9
KMC3420
KMC3420's Avatar
Re: What year 5.3?
Thanks for serving also, just saw that.
Keagan
Old 04-30-2014, 03:30 PM   #10
dman1982
dman1982's Avatar
Re: What year 5.3?
No problem, I got out in jan after 12 years
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 05-01-2014, 08:34 PM   #11
71chevystep4x4
71chevystep4x4's Avatar
Re: What year 5.3?
Mines the first year 1999 5.3L which only had 89K on it, and I am very pleased every time I drive her, better power and response than any of the previous engines I've had in her. It's 4x4 with 4 speed and 33" tires, and will burn um off no problem.
71chevystep4x4 is offline   Reply With Quote
Old 05-01-2014, 10:57 PM   #12
KMC3420
KMC3420's Avatar
Re: What year 5.3?
I am thinking the same thing. Any 5.3 is a step up. I am probably going to look for an 04 or 05 with a 4l60e. Thanks for the help.
Keagan
Old 05-02-2014, 01:31 AM   #13
littlevictories
Re: What year 5.3?
dont get hung up on this year or that year
find something complete with good compression and oil pressure and bolt it in
littlevictories is offline   Reply With Quote
Old 05-02-2014, 08:35 AM   #14
KMC3420
KMC3420's Avatar
Re: What year 5.3?
Okay, I wont get hung up on any years, just let me know if there are any years to avoid.
Keagan
Old 05-08-2014, 07:41 PM   #15
OldRuffiaN
Re: What year 5.3?
Starting in`05 GM went to much stronger rods/bolts with floating wrist pins as opposed to pressed in.This seems to have cured the piston slap issues with earlier versions and are much stronger overall if you`re considering boost/nitrous.
OldRuffiaN is offline   Reply With Quote
Old 05-08-2014, 08:19 PM   #16
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: What year 5.3?
Piston slap, while it does exist, occured in a fractional minority of the engines released. The issue was most prevalent on the all-aluminum early motors due to the metallurgy, and some of the 99-01 truck engines had the issues as well. Most of the time, the problems people label as "piston slap" really aren't.
The rod bolts is even more of a hit-or-miss issue. Again, it was mostly an early year issue. Most of the rod bolt failures that occured did not happen due to raw mechanical failure under normal circumstance. A large majority failed after having already been re-used, so failure to follow proper torque procedures added to the amount of sheared bolts. Additionally, most failed during high-rpm or sudden detonation situations...NOT failing under boost load. The sudden and impactful hit of nitrous, or the shock of detonation at high rpm are far more likely to destroy a rod bolt than boost.
Shortly after the issue was "addressed" circa 05-ish, stories still came out of wrecked rod bolts. The truth seems to be that the use, maintenance, installation and stresses all applied to the failure rate...and could pretty much do the same damage to any year. Anyone looking to go the the "next level" of mods should consider the upgrade as an option, but my no means an absolute requirement, regardless of year.
IMO, there are only 2 engines to avoid. The first one to avoid is any LS1 that you don't know the history of. Why? Due to the desireability of the "name", they are usually overpriced, well beaten, and are the oldest. These are the engines inhabiting the earliest f-bodies and corvettes, and have been treated as such. The 98's also have special wiring and ecm situations that makes them a pain.
The other engine, is the 99-00 first-run truck engines with the Iron heads. The weigh the most, the heads are inferior to any of the Aluminum heads, and again they are the oldest and most likely to have high miles. Also, the early trucks had a flywheel spacer built in, making it so the 4l80e is pretty much your only tranny option.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-08-2014, 10:46 PM   #17
KMC3420
KMC3420's Avatar
Re: What year 5.3?
Thanks guys. That is the info I was needing. I am going to have my guy look for an 04 or 05 as a start then go from there out of a truck. 5.3 would be my first choice. I don't have plans or the funds to add a turbo or anything at this time so that's not an issue. I just want a dependable DD for now.
Keagan
Old 05-09-2014, 12:12 AM   #18
solidaxel
solidaxel's Avatar
Re: What year 5.3?
Good choice !
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-13-2014, 11:39 PM   #19
66LSx
66LSx's Avatar
Re: What year 5.3?
I wanted to 'try' to get into an 04-05' non-flex for having the most common ECM, injectors, and returnless fuel system while still being DBW...(while not really important... it did save me $$$$ with not having to run 2 sst braided lines up the chassis from my rear mounted tank vs. returnless
SOME IMPORTANT INFORMATION regarding 5.3L vortecs
Injectors (non flex)
PN 25317628 2001-2007 - 4.8L, 5.3L, 6.0L - flows 3.180 gm/sec or 25.2lb/hr @ 58 psi
03+ throttle body: 8 pin connector on passenger side only
tac module: 99-02 all plastic, 2003+ plastic with metal mounting bracket
VERY important to do your homework (or get all the stuff from the same truck) regarding gas pedal, pedal TCM unit, engine ECM itself, the potential wiring harness uncut if possible... otherwise you REALLY have to pay attention to making sure your sourcing components that play nice from the correct model years.
1966 C10 SWB Fleet
5.3L LM7 Vortec / 4L60e Swap
1966 C10 w/ 5.3L/4L60e Build Thread
2012 GMC Sierra 5.3L 4x4 CCSB
66LSx is offline   Reply With Quote
Old 05-14-2014, 10:16 PM   #20
KMC3420
KMC3420's Avatar
Re: What year 5.3?
Thanks for the tips. I have intentions of getting everything from the same truck. Hopefully it won't be too difficult.
Keagan
Old 05-14-2014, 10:18 PM   #21
KMC3420
KMC3420's Avatar
Re: What year 5.3?
66lsx. Your install looks very clean. Nice job.
Keagan
Old 05-15-2014, 12:13 AM   #22
ivorton74
ivorton74's Avatar
Re: What year 5.3?
So did all 99-00 5.3 have iron heads?...cuz I got a 99 5.3 and I was told it has aluminum heads...also my flywheel doesn't have a spacer
1983 C10 Silverado 5.3 swap
1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122
2001 BMW 530i 5 speed
2019 Nissan Titan SV Midnight
1979 Datsun 210 4 door
1980 Datsun 120y(back home in Trinidad)
ivorton74 is offline   Reply With Quote
Old 05-15-2014, 12:27 AM   #23
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: What year 5.3?
That only applies to the 6L's
Old 05-15-2014, 05:10 PM   #24
ivorton74
ivorton74's Avatar
Re: What year 5.3?
ohh my bad
Old 05-15-2014, 07:29 PM   #25
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: What year 5.3?
ohh my bad
I should've specified, for whatever reason I thought I had implied it. Reading it back, I just said "Truck".
