Old 04-30-2014, 01:58 PM   #1
dman1982
dman1982's Avatar
gauge question
what you guys running for gauges? i got a 04 5.3 (as many of you know lol) and just curious what you guys are running? whats the best way to go? isn't it a simple hook up from the stock senders to the gauge? or is there more to it? looking to order some gauges today after i get done at the post office (gotta return a part)
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
Old 04-30-2014, 04:15 PM   #2
dman1982
dman1982's Avatar
Re: gauge question
and since i have a VSS i can use a electrical speedo right?
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-30-2014, 05:31 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: gauge question
You can use a digital/electric speedo
Volt gauges hook up as normal.
Fuel gauges hook up as normal but you may need a resistor if the gauge sweep doesn't match the Ohm output from the sending unit.
Oil pressure (analog) hooks right up so any pressure source.
Electric coolant temp and oil temp/pressure sensors may need a different sending units depending on the gauge. Just as with the fuel gauge, the resistance sweep determines compatability.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-30-2014, 05:33 PM   #4
dman1982
dman1982's Avatar
Re: gauge question
Thanks man...any advice on what gauges to get? (I went to send out that harness today but we had some nasty weather so I didn't leave the house)
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-30-2014, 07:41 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: gauge question
I just put gauges together as I need them. I never feel like spending the $$$ for "matching" sets, since I always need to add a gauge that doesn't exist in that "line".
I had a matching set of Sport Comp gauges, but wanted a different size that that they didn't have. but another company did, so that threw of the "Scheme". Now I only care if its a black face with white numbers....if so, I'm good.
Autometer, Autogage (who is autometers budget line) are of course good gauges. Equus makes some decent ones, but do a little research as some of them are a little cheesy. Stewart warner and Sunpro have offerings as well, its really a balance of budget vs looks.
Old 04-30-2014, 08:03 PM   #6
dman1982
dman1982's Avatar
Re: gauge question
I'm looking for good and budget loo
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-30-2014, 08:54 PM   #7
Andy4639
Old member
Andy4639's Avatar
Wink Re: gauge question
I used the www.speedhut.com gauges and the GPS speedometer. I love them. The speedo doesn't care what size tire what gear I have it's dead on the mark no matter!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-30-2014, 09:04 PM   #8
dman1982
dman1982's Avatar
Re: gauge question
those are pretty sweet man, but i think your budget is waaay bigger than mine lol
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-30-2014, 09:37 PM   #9
Andy4639
Old member
Andy4639's Avatar
Just use the speedo and not have to worry about it.
Old 04-30-2014, 09:47 PM   #10
dman1982
dman1982's Avatar
Re: gauge question
That's what my buddy said, I already have the ecu calibrated for the gears, and for about the price of the speedo I can almost get all the gauges, I really only need the water and oil pressure gauges, but roils like the clean cut look of all matching gauges
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-30-2014, 10:00 PM   #11
66LSx
66LSx's Avatar
Re: gauge question
Speedhut x2 in my 66' C10 / 5.3 Vortec.....
1966 C10 SWB Fleet
5.3L LM7 Vortec / 4L60e Swap
1966 C10 w/ 5.3L/4L60e Build Thread
2012 GMC Sierra 5.3L 4x4 CCSB
66LSx is offline   Reply With Quote
Old 04-30-2014, 11:33 PM   #12
Andy4639
Old member
Andy4639's Avatar
Talking Re: gauge question
You can use all the factory gauges if you don't mind running them off the motor and not the computer. I also bought the ww.scangauge.com and have it mounted in the ash tray opening. It reads straight off the computer. You can clear cods and set the gauges you want with it also.
Old 05-01-2014, 01:38 AM   #13
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: gauge question
I used the Scanguage as my speedo and skipped the $500 of extra shiny things in the dash.
I really only have 3 gauges; tach, oil pressure and the scangauge. I have a duplicate voltmeter that just takes up a space I'm saving for a wideband. The Scanguage does the speed, volt, coolant temp, and IAT currently.
Old 05-01-2014, 02:07 PM   #14
PGSigns
PGSigns's Avatar
Re: gauge question
There is the Dakota digital VHX stuff also. One of the vendors here had some good pricing on them.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-01-2014, 07:17 PM   #15
mooseknuckles
mooseknuckles's Avatar
Re: gauge question
autometer, american muscle. electric.
mooseknuckles is offline   Reply With Quote
Old 05-01-2014, 07:50 PM   #16
dman1982
dman1982's Avatar
Re: gauge question
Dude...BA
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 05-01-2014, 08:11 PM   #17
mooseknuckles
Re: gauge question
Dude...BA
thanks bro...
Old 05-01-2014, 09:03 PM   #18
dman1982
dman1982's Avatar
Re: gauge question
I think I'm going to go with the autometer quad setup with a electric speedo, and a clock
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 05-04-2014, 11:31 AM   #19
dman1982
dman1982's Avatar
Re: gauge question
I ended up going with these gauges
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 05-04-2014, 01:09 PM   #20
Hart_Rod
Hart_Rod's Avatar
Re: gauge question
I really like the VHX's for LS swaps. Very simple install with a lot of functionality.
Hart_Rod is offline   Reply With Quote
Old 05-04-2014, 01:11 PM   #21
dman1982
dman1982's Avatar
Re: gauge question
Those are pretty sweet...I got mine for about three hundo...my Wolfe don't know about that account!!!
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 05-04-2014, 03:59 PM   #22
jorgensensc
jorgensensc's Avatar
Re: gauge question
Speedhut. Not cheap, but well worth it in my opinion.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 05-05-2014, 04:07 AM   #23
kevmac
kevmac's Avatar
Re: gauge question
www.youtube.com/watch?v=JSlhavNohDQ
Yea thats nice!
I'll watch a rev J vid just for the intro
kevmac is offline   Reply With Quote
Old 05-05-2014, 06:21 PM   #24
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: gauge question
Originally Posted by kevmac View Post
Yea thats nice!
Old 05-10-2014, 08:18 PM   #25
dman1982
dman1982's Avatar
Re: gauge question
so i got a random question, i went to install my gauges, and the temp sending unit doesn't go in the side of my head (5.3), does anyone know what adapter i can use? PN? or is there a sending unit i can use from another vehicle?
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
