Old 04-30-2014, 05:48 PM   #1
mrdave03
mrdave03's Avatar
3 Speed trans oil 90W?
I'm told I should run plain old 90w gear oil in my recently rebuilt 3 speed on the tree non synchro trans. I can't find it anywhere. The guy who sold me the trans said never use a GL5 in it nor a synthetic. Anybody know what would work or if 90w is available. I checked most auto parts here in northwest New Jersey to no avail...
mrdave03 is offline   Reply With Quote
Old 04-30-2014, 06:02 PM   #2
crhyno
crhyno's Avatar
Re: 3 Speed trans oil 90W?
I last found this at my local West Marine. It is closed now but I know they are still open elsewhere. Good Luck.
crhyno is offline   Reply With Quote
Old 04-30-2014, 07:02 PM   #3
hotrod66
hotrod66's Avatar
i used 80/90 gear oil from Orileys auto parts. worked fine when i had mine rebuilt it is still in there 3 years later and no trouble and i drive mine like i stole it.
Between saying and doing many a pair of shoes are worn out
hotrod66 is offline   Reply With Quote
Old 04-30-2014, 10:47 PM   #4
Wrenchbender Ret
80/90 is the replacement for 90 weight. There is nothing wrong with using GL5 in that type trans.
Wrenchbender Ret is offline   Reply With Quote
Old 05-01-2014, 09:43 AM   #5
66Submarine
66Submarine's Avatar
From what I've read the straight 90W will shift better/quicker. GL-5 is supposed to generally be somewhat corrosive to the brass parts in the trans. You can get straight 90W at Napa. (about to try some in my SM420...)
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 05-01-2014, 11:18 AM   #6
WhippinSaw
WhippinSaw's Avatar
Sta-lube makes a gl-4 gear oil, Sold at napa, gl-4 is reccomended in the service manual. not sure whats the difference is but I used it just to be safe after I read gl-5 could attack brass parts.
http://www.napaonline.com/Catalog/Ca...229_0006410049
1963 Fleet Side cab, Converted Fleet Side Barden bumper, Step Side in the middle.
WhippinSaw is offline   Reply With Quote
Old 05-01-2014, 12:20 PM   #7
mrdave03
mrdave03's Avatar
Thanks! Yes I had read about GL5 being corrosive to brass as well. I did find the CRC Sta-Lube 80W-90 GL4 at Napa so to be safe I'll be running it.
Old 05-01-2014, 07:03 PM   #8
66Submarine
FWIW, I just changed the oil in my SM420 to the straight 90 GL-1 that NAPA sells (part number "NHF 65201"--says 65-201 on container). Initial impressions are that it certainly seems to shift quicker with the GL-1. And it's "cheap" @ $13 a gallon, too. Works for me!
