Old 04-30-2014, 05:59 PM   #1
Special-Ed
Special-Ed's Avatar
oh crap... P0430 code
drove to chicago from floriduh. Looks like i am now getting a P0430 code... no prior codes or ces lights prior to this trip.
so i swapped out the right side O2 sensors, the rear one was blackity black... the front looked normal. stupid code comes back. truck runs great, no noticable misses, no noticeable head gasket water leaks, no noticable problems. no vacuum leaks that i can tell...
for 1300 highway miles she ran strong... tool around chicago bam code....
at highway speeds i notice i get no codes... but if i run the cook county forest preserve roads at 45-50 bam get a code...
florida no codes... chicago codes...
im swapping out the plugs and wires in the morning... and air filter.
already cleaned the throttle body/butteryfly, ran it empty and put premium mobil gas in it.
anything else i should look at before i have to pony up 800 bucks to replace the cats?
i do have a cheapy hand held scanner with me, but i see nothing noticable out of spec.
a p0430 is a right bank(passenger side) issue... so that eliminates anything in common with the left bank...
thanx
ed
Ed will be known as the Tiger Woods of the integration business
Special-Ed is offline   Reply With Quote
Old 04-30-2014, 10:12 PM   #2
cableguy0
Re: oh crap... P0430 code
First step is to change the plugs and run fuel injection cleaner. Fuel injection cleaner will also clean some of the crud out of the cat if there is any. Chevron with techron is the best stuff on the shelf. City driving is harder on the engine than anything else and constant stops and starts will produce more emissions. The systems are sensitive and sometimes there will be no indication of the problem other than the code. Depending on mileage changing out the cat might NOT take care of the light. I see it a lot at work. Some vehicles also have an issue when they get a bit older that the computer actually needs reflashed. Standard procedure at most stealerships is to replace the cats and reflash the computer when most likely the reflash was all that was needed.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 04-30-2014, 10:47 PM   #3
Special-Ed
Special-Ed's Avatar
i violated my number one rule...
2005 chevy suburban z71 factory(no mods) 202,000 miles
any recommendations on a cleaner? or just any of the top dollar stuff available at any part store? i thought chevron was a gas station...lol
Old 04-30-2014, 11:32 PM   #4
4Eyedtruck
Does Florida require emissions ? If not cut them out and tune them out
4Eyedtruck is offline   Reply With Quote
Old 04-30-2014, 11:42 PM   #5
Special-Ed
Special-Ed's Avatar
i would rather fix it properly....
Old 04-30-2014, 11:59 PM   #6
4Eyedtruck
I had the same codes on mine and replaced all the o2 sensors and the fuse that blew when the code was set off ran great same 21-22 mpg on the highway
back in September I installed a 212/218 cam longtube headers and off-road y-pipe no cats tuned them out and still get the 21-22 mpg it's just harder to keep my foot out of it now point being there is more than one way to skin a cat
Is the code coming off and on intermittently or are you clearing it with the scanner soon as it pops up?
Old 05-01-2014, 12:06 AM   #7
Special-Ed
Special-Ed's Avatar
i clear , it comes back... a while later...
it will be fixed come hell or high water by friday =)
if this was a project truck i would not worry about it and just tune them out.
Old 05-01-2014, 12:13 AM   #8
4Eyedtruck
Check your fuses it's a long shot but maybe yours was like mine their is a fuse that can blow when the o2 sensor goes bad after I replaced my o2 sensors the light kept coming back on finally got on all data found that fuse checked it and it was blown bad thing is I can't remember where it was believe it was in the fuse box under the hood been 3 or 4 years now soon as I replaced fuse no more light worth a look atleast
Old 05-01-2014, 01:02 AM   #9
Special-Ed
Special-Ed's Avatar
that might be the o2 heater fuse?
Old 05-02-2014, 09:49 AM   #10
4Eyedtruck
It's possible it's been so long since mine went bad I'll try and get on all data today sometime and look it up for you
Old 05-02-2014, 03:53 PM   #11
Special-Ed
Special-Ed's Avatar
I put in a double dose of the chevron stuff... its raining in chicago and i dont have a garage here so plugs and wires will wait another day.
oh well i got blackhawks games to be at... it can wait til monday...
Old 05-05-2014, 02:41 AM   #12
austinstocker
austinstocker's Avatar
IMO the only thing that is going to fix a catalyst low efficiency code is to replace the cats, unfortunately.
____________________________
1967 C10 SWB Big Block 4 Speed
austinstocker is offline   Reply With Quote
Old 05-05-2014, 04:28 PM   #13
Special-Ed
Special-Ed's Avatar
These spark plugs have 110k miles on them
Old 05-05-2014, 04:39 PM   #14
Special-Ed
Special-Ed's Avatar
Original o2
202k miles. The dirty one is the secondary.
Old 05-09-2014, 11:40 AM   #15
69gmcc10
69gmcc10's Avatar
I know it sounds odd, but take a few min to hook up a voltmeter and test your MAF (google the procedure). If the MAF is going bad it can create a rich condition and clog a cat. I replaced 2 cats before I found out it was my MAF.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
