Old 04-30-2014, 07:06 PM   #1
c10seth
c10seth's Avatar
Too Rich: SBC 670 Holley Street Avenger
Hey, all.
I have a 360ci SBC with an Edelbrock top end kit #2022. Compression ratio is about 10:1. 93 octane fuel with Stabil left over from winter storage.
http://www.jegs.com/i/Edelbrock/350/...FcURMwod_xwA4A
I have the timing set to 12* BTDC at idle and 36* of Mechanical timing ~2,500 RPM (Vacuum advance disconnected & plugged). I installed a fresh set of spark plugs gaped to about .040" and within about 20 min of idling the truck wouldn't idle any more because the plugs were fouled out. I was getting between 5" and 10" of Hg at idle and I know it should be higher than that. A knowledgeable buddy of mine suggested it could be the Power Valve (PV) or my floats are set too high. I think my floats are ok as the the fuel level is just below the threads, from what I can see. As anyone had any issues like this? Thank you.
Kindest Regards,
c10seth
c10seth is offline   Reply With Quote
Old 04-30-2014, 08:12 PM   #2
geezer#99
geezer#99's Avatar
Re: Too Rich: SBC 670 Holley Street Avenger
Hook your vac advance up to manifold vacuum, your idle and vacuum will come up, turn down your idle and adjust your mixture screws. Presently you're likely idling on the power circuit and with a low vacuum your power valve could be opening.
Old 04-30-2014, 08:37 PM   #3
67 chevelle
67 chevelle's Avatar
make sure your choke is not stuck closed
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 05-01-2014, 09:36 AM   #4
msgdsrf
Both good suggestions. Your vacuum definately should be higher with that setup, idle in gear with say around 14". What is your idle speed?
msgdsrf is offline   Reply With Quote
Old 05-01-2014, 01:10 PM   #5
c10seth
c10seth's Avatar
I will give this a shot. Thank you much.
Electric choke seems to be opening and closing fine, but I'll keep a close eye on it.
idle speed was between 500 and 900rpm. I had to adjust the curb idle to keep it from stalling. I'll reconnect the vac. advance and go from there.
Thank you all,
c10seth
Old 05-09-2014, 07:14 AM   #6
c10seth
c10seth's Avatar
Hey, all.
I reconnected the vacuum line for the dizzy advance, threw in a new set of plugs, and wow. That made a huge difference. I was getting about 20inHg and she stopped belching black smoke. I didn't realize that was that big of a deal with this Holley 670. Thank you for your help ^_^
Seth
Old 05-09-2014, 09:47 AM   #7
67 chevelle
Funny it turns out to be a distributor issue , when all indications would point towards the carb
670, float, holley, power valve, too rich
