two trucks one key
Just thinking I have a 68 and a 70 is there any way to get 2 ignition switches and four door looks that would all be keyed the same? It would cut down on keys, any thoughts?
Ron
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
The Older Generation
Re: two trucks one key
Yes, it is do-able. You would have to get a complete set of locks that are compatible (same keyway) for the 2nd truck so they could be keyed the same. '68 uses the "C" keyway and '70 uses the "J" keyway.... I can do it.. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 04-30-2014 at 11:28 PM. |
How much? Thanks for reply.
Ron
If you want to send me the key from one of your trucks and the locks from the other one it would run $25 plus shipping to match a set of door and ignition locks to the key you send..
LockDoc
Now that's the way to do it.
" Dead Pumpkin" 67 Chevy short bed, 292 I6, 4spd manual. Fan of the "Slant Noses". ![]() 93' Toyota pickup 2WD 2dr and 32mpg. Daily driver. 300k+ Members I've met... Mister-B |
How much for locks and ignition to match the 70?
Ron
Its convenient to a point. When I was running two different Saturns to work alternately I just cut a key to match each car on one side of the key. Then I'd just flip it for the car I needed to open. Unless you drive both trucks alternately a lot I'd just keep it two different keys.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Using Locks I have without trading yours in would be another $12
LockDoc
my ignition switch is so loose I can use my scion key...
I might have to go pull my door locks off soon I'm really tired of having 3 separate keys for one truck
1969 Chevy C10 2wd stepside longbox |
#11 | |
![]() LockDoc
I like your idea but a theif that found your key would like it better, two for the price of one.
#13 | |
He can only drive one at a time.... ![]() LockDoc
