Old 05-01-2014, 09:31 AM   #1
BigSix
Pitman Arm for 4x4 Power Steering Swap
I have a Lares 959 power steering box going in my 65 3/4 ton 4x4. This is from a 69 K20. What years can I pull a pitman arm from? If you have one that will work let me know also! There are some decent junkyards around here so I should have a chance at finding an arm.
BigSix is offline   Reply With Quote
Old 05-02-2014, 12:11 AM   #2
Captainfab
60-66 Nut
Re: Pitman Arm for 4x4 Power Steering Swap
I would use the one that is on the steering box. I believe it is the same as most K series pitman arms. If you could get the steering arm for the '69 K20 that would work as well as the draglink
Old 05-02-2014, 08:56 AM   #3
BigSix
I don't have a pitman arm so I'm looking for a year range to use when hunting the junkyard.
Old 05-02-2014, 10:35 AM   #4
Captainfab
60-66 Nut
As far as I know '68-'87 should be the same or at least interchangeable.
Old 05-02-2014, 11:33 AM   #5
61K10
61K10's Avatar
I used a dropped arm from skyjacker. It leveled the drag link better than a stock one
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
