Old 05-01-2014, 02:50 PM   #1
Mossbeard
Educate me: why all the rusty fenders?
I've recently acquired my first truck; a '66 C20. I've been learning a lot here but I'm wondering what causes the rust patches I've seen on so many front fenders (lower edge behind wheel)? Is there a design flaw? More important, after repairing the rust, what can be done to prevent recurrence while still keeping the truck looking original?
Mossbeard is offline   Reply With Quote
Old 05-01-2014, 02:57 PM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Educate me: why all the rusty fenders?
There's a drain hole that wasn't made big enough to allow the silt that builds up in there from draining. Moisture and dirt gets trapped in there and it rusts away.
Some here have made the drain hole bigger.
One just needs to blast some water in there to flush it out from time to time.
66 C20 Service Truck:
Old 05-01-2014, 02:57 PM   #3
NEWFISHER
NEWFISHER's Avatar
Design flaw that traps moisture at the lower section. Same with the cab corners on GM trucks all the way into the late 70's. When you come across an original cab corner in good shape, it most likely has a 3/8 hole drilled in it to let the water run out. That was a mod done by an owner who was aware of the issue many years ago.
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 05-01-2014, 02:59 PM   #4
Improbcat
Improbcat's Avatar
There is a bad design that traps water/dirt in the fender brace attached there and causes it to rot out.
Things that help are to drill a decent sized drain hole at the bottom of the brace and to seal the edges & top of the brace with seam sealer to keep the water/dirt out in the first place.
1964 C/10 Longbed Fleetside, base model. (build thread) (pictures)
SOLD 1964 C/10 Shortbed Fleetside, Deluxe. (pictures) SOLD
Improbcat is offline   Reply With Quote
Old 05-01-2014, 03:14 PM   #5
Mossbeard
Thanks everyone! That's exactly the info I was looking for. Very helpful.
Old 05-01-2014, 03:56 PM   #6
1963c-10
1963c-10's Avatar
Don't forget the rusty hoods, floor pans, rockers (inner & outer) and inner fenders.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 05-01-2014, 04:02 PM   #7
Mossbeard
Yeah, I get a trickle of water from behind the dash on the passenger side when it rains. If I don't find the leak soon I'll have rusty floorboards.
Old 05-01-2014, 04:03 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Mine rusted there as well, but strangely it did so in a very concentrated manner. I actually had about a quart of sand in that area, which held the moisture and caused it just to rust there.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-01-2014, 04:11 PM   #9
1963c-10
1963c-10's Avatar
Check the roof seal....and the firewall where it meets the cab. Also check the windshield gasket as sometimes they get loose and I've seen water come in there also.
Old 05-01-2014, 04:37 PM   #10
WhippinSaw
WhippinSaw's Avatar
I want to power wash my lower front fender after watching this youtube video on 1960 to 1966 front fender rust repair . It shows why the fender rust at the 7 minute marker https://www.youtube.com/watch?v=oydlEWgNths#t=293
1963 Fleet Side cab, Converted Fleet Side Barden bumper, Step Side in the middle.
WhippinSaw is offline   Reply With Quote
Old 05-01-2014, 08:06 PM   #11
markeb01
Senior Enthusiast
markeb01's Avatar
IMHO the drain hole is big enough, if nothing is allowed in to begin with. Unfortunately GM designed the fenders to collect debris and form a compost pile in the lower fenders until the sheet metals bursts open on the front side. The only way to prevent it in the future is to close all the openings into the fender brace. Here’s how I permanently fixed mine:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
