Old 05-01-2014, 05:26 PM   #1
donthekawguy
donthekawguy's Avatar
small crack at PS mount-should I fix?
Got my PS box off and found a crack between two holes in the frame. Is it worth having a mobile welder come over and fix it or just leave it alone. I'm going to need a captfab adapter anyway so I thought it would be ok. Any thoughts? BTW if you cant see it, the crack is on the right side of the hole and its cracked twice so the little piece of metal will fall out if I move it.
66 shorty
donthekawguy is offline   Reply With Quote
Old 05-01-2014, 05:32 PM   #2
KJSR
KJSR's Avatar
Re: small crack at PS mount-should I fix?
I would clean it up and see if the cracks go anywhere besides the two holes.
1936 Chevrolet 1/2t
1964 Chevrolet C10
1964 Chevrolet C10 (sons)
1965 Chevrolet K10 Suburban
1969 Chevrolet C10
1937 Plymouth P4
KJSR is offline   Reply With Quote
Old 05-01-2014, 06:06 PM   #3
padresag
you actually have 3 cracks, 1 radiating upwards. there may be others around the other holes. the bracket will not those cracks from expanding. you will now have added stress on there with the power assist and make it easier for that to flex. the frame will move before the turning action of the vehicle. have all cracks there repaired properly. your life and others. they would pull your vehicle off the road for those cracks.
if you happen to get in a serious accident, if those cracks are found and if they find out if you had prior knowledge that you knew; your ass would never belong to you again.
ron
padresag is offline   Reply With Quote
Old 05-01-2014, 06:28 PM   #4
bonehead
bonehead's Avatar
X2 ...repair the cracks and prevent a future disaster.
past trucks:
1980 C-10 Silverado SWB
1961 C-10 custom cab LWB
1966 C-10 custom cab LWB
bonehead is offline   Reply With Quote
Old 05-01-2014, 08:11 PM   #5
donthekawguy
I took my control arms to a guy I know from car shows in the area today and while he was popping out the ball joints and shafts I asked him about the cracks. He said he could swing by and weld them up while I have the front suspension off. Ten minutes of welding is a lot better than hurting someone. I also found a broken u bolt on the lower control arm so I'm glad I'm doing this rebuild. Looks like I got to things just in time.
66 shorty
Old 05-01-2014, 08:22 PM   #6
PGSigns
PGSigns's Avatar
Need to pull that bumper bracket. Looks like a crack running that way to. Before you weld them up drill a 1/16" hole at the end of any cracks that don't stop at an edge.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-01-2014, 11:56 PM   #7
donthekawguy
Thanks Jimmy I didn't even see that one. I wanted to pull the bumpers and grill for powder coat anyway. Now I have a good reason. I was planning on buying a welder this fall maybe this will motivate me to do it now. lol
66 shorty
Old 05-02-2014, 06:33 AM   #8
PGSigns
PGSigns's Avatar
The holes in the end of the crack will keep it from going any further. When yo weld it up take a grinder and V the crack out to get a full penetration weld.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 05-02-2014, 07:40 AM   #9
donthekawguy
Cool thanx! I heard of the hole thing before but would have never remembered it.
66 shorty
