Old 05-01-2014, 09:25 PM   #1
rickywideglide
rickywideglide's Avatar
another brake question
1964 c20, after adjusting f. brakes(drum) pedal seems to have very little movement and hard, brakes seem to work, it has power booster whats easiet way to check ive heard pump pedal then start truck and it should collapse some . im planning on doing dual m.c upgrade soon just wasnt sure if i need to replace booster as well, i believe it has the horizontal linkages
rickywideglide is offline   Reply With Quote
Old 05-02-2014, 09:00 AM   #2
1963c-10
1963c-10's Avatar
Re: another brake question
Normally a hard brake pedal is a clogged line or a brake shoe is stuck. Have you bled the lines to verify good fluid coming out? Might be worth pulling the drums to inspect the shoes also.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 05-03-2014, 10:48 PM   #3
rickywideglide
thanks for reply,yea checked out shoes ,gonna do the dual mc upgrade just researching what parts to get to split lines
