Old 05-02-2014, 07:41 AM   #1
R&K's71
Installing a newer overdrive tranny
Hey guys I have a 79 Big 10 with your standard 350/350 combo was curious about installing a newer tranny with overdrive. Any Info and where would I start. Also if there is a thread already on this topic please point me in the right direction. Thanks for the help.
R&K's71 is offline   Reply With Quote
Old 05-02-2014, 08:41 AM   #2
solidaxel
solidaxel's Avatar
Re: Installing a newer overdrive tranny
Do the whole package 5.3 and the 4L60E you will be very surprised getting 20MPG and extreme performance!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-02-2014, 08:56 AM   #3
andrewmp6
If your keeping your 350 get a 700r4.
andrewmp6 is offline   Reply With Quote
Old 05-02-2014, 09:40 AM   #4
bilfman
bilfman's Avatar
Here is my install of a 4l80e, 4l60e would be the same. It went much smoother then anticipated. Turned out to be an easy swap.
http://67-72chevytrucks.com/vboard/s...d.php?t=537481
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 05-02-2014, 09:42 AM   #5
cleansquare
I did the 4l80e swap as well. Really not much to it
cleansquare is offline   Reply With Quote
Old 05-02-2014, 03:16 PM   #6
gramps77
I did the 700r4 in my 77 Big 10. Utilized Bowtie Overdrives TV cable, moved my stock transmission mount back, and a local builder for the transmission. It REALLY is very easy.
Also used electric lock up which utilizes a cruise control brake pedal switch to shut off lock up from Bowtie.
gramps77 is offline   Reply With Quote
Old 05-02-2014, 03:45 PM   #7
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
I also did the TCI EZ-TCU kit to control a 4L60E. Very impressed with the TCI kit, pieces and shift quality. Programming the TCU is a snap. Love the electronically controlled trans over any 700R4 I've ever owned. Shift quality is so much nicer.
Story HERE.
DirtyLarry is offline   Reply With Quote
Old 05-02-2014, 08:16 PM   #8
Ziegelsteinfaust
If I kept my C20 a 2wd I would of gone with a 4L65E or if you use yours for serious work a 4L80E.
The E series has a bit better of a lock up function with a loose converter which was important to me.
Ziegelsteinfaust is offline   Reply With Quote
