Old 05-02-2014, 10:03 AM   #1
Malice
What is your set up?
So i want to make a thread on what you set up is. Why you went with what you did and would you change it if you could?
Example. What engine, transmission, tire size and rear end gearing?
Why did you pick that set up? Would you change it if you could?
I'd also like to hear peoples mileage they are getting, your 0-60 time and 1/4 mile time if you have it.
I've just been trying to find info lately to help me figure out what set up to go with and you just can't find this info anywhere.
Malice is offline   Reply With Quote
Old 05-02-2014, 02:05 PM   #2
OrrieG
OrrieG's Avatar
Re: What is your set up?
http://67-72chevytrucks.com/vboard/s...62&postcount=1
Since that first post I upgraded the engine for 4bolt 355 truck with mild cam, edlebrock intake and q-jet carb. TH350 w/ NP203 transfer with shaft part time conversion, k10 front and rear axles with 3.73 ratio. With the 283 I got about 14-16 mpg with a Rochester 2GC carb. Expect the same from 355 based on the same setup in my 64 Chevelle.
OrrieG is offline   Reply With Quote
Old 05-02-2014, 02:35 PM   #3
stewdecky
stewdecky's Avatar
I went with a 350/350 combo. s-10 frame swap and s-10 blazer rear end. get 16-17 mpg on the highway. Wish i had a 700r4.
stewdecky is offline   Reply With Quote
Old 05-02-2014, 06:07 PM   #4
_Ogre
_Ogre's Avatar
0 to 60 time is almost instant, i just don't move anywhere
shop air compressor timer
Old 05-02-2014, 08:17 PM   #5
blue57
blue57's Avatar
I am running a LS1 with 4l60e transmission. Currie 9" 370 gears. Wasnt sure what rearend was in the truck and was wanting disk brakes. Went with this setup due to the reliability, power and mileage i can get from the LS motor. I am going to run a 20" rim in the rear and 18 up front. At least that is the plan for now.
my build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=522711
blue57 is offline   Reply With Quote
Old 05-02-2014, 09:27 PM   #6
joe trav jr
joe trav jr's Avatar
I am running LS2 6.0 with 6l80E, 2.72 rear, 19 mph. Nova front clip, mustang II steering, front disc. 275r15 rear 215r15 front tires. I was concerned about the rear end being OK for long hauls, not so much coming out of the hole. Boy was I wrong? If I get into it tires will break loose in 1st, 2nd, and 3rd before they stop spinning.
"Buttercup"
joe trav jr is offline   Reply With Quote
Old 05-03-2014, 12:08 AM   #7
oldman3
oldman3's Avatar
I'm running a 350/350 combo (325 hp), 74 Nova rear axle with 2:56 gears. Rear tire is a 235/55/17, 9.6" section width and 27.2" tall, wheels are 17X8" with 3-1/2 backspacing. Gas mileage is 17 running 70MPH, and I'm turning around 2400 to 2500 RPM. I figured that a 3:73 ratio with overdrive (70%) equals 2:61 so I went with the 2:56. Hope this helps...Jim
oldman3 is offline   Reply With Quote
Old 05-03-2014, 01:01 AM   #8
broey
Square
broey's Avatar
im running a 350/350 combo, because I like small blocks and ls motors are ugly. Porterbuilt front and rear because well...Porterbuilt, and 15's with wide white biasplys because my friend is awesome and hooked me up.
Squarebody Syndicate
broey is offline   Reply With Quote
Old 05-03-2014, 09:27 AM   #9
crossfire84
crossfire84's Avatar
BBC 396 stroked 1/4", Richmond 6spd overdrive, C4 rear end with 3:08 gears. I"ll be happy with 10-12 mpg. All these parts were left overs from my home business.
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 05-07-2014, 04:31 PM   #10
62lwbc10
Im running a brank new 350/290 with a mildly worked TH 350, stock rear. smokes tires easily, chirps second at 40% throttle. 55 MPH around 2600RPM. Horrific gas mileage but I LIKE IT!
62lwbc10 is offline   Reply With Quote
Old 05-07-2014, 04:58 PM   #11
mark '87 930
mark '87 930's Avatar
I run a SBC with a qjet carb. nothing too strong HP/Torq wise, so i run a nice T5 tranny now. Stock rear end (4.10 gears) with 29" tires all around. I average 17mpg on the highway and 12ish in the city. I'm at about 1900rpm on the hwy doing 65mph.
I have no idea what my 1/4 mile time would be or my 0-60 for that matter, I just don't drive it that way. I love power, but unless it's a sports car, I don't see much of the point in these trucks. Let me also say that i certainly would not turn down a 350-400hp motor . I have mine setup this was as i put about 7-10K miles on it every summer going to and from the cottage. It's mainly my driver in the summer time.
mark '87 930 is offline   Reply With Quote
Old 05-08-2014, 10:17 AM   #12
buggy5872
buggy5872's Avatar
59 3100 fleetside.... 355 SBC with 700R4 and Dana 44 with 3.73 gears. Camaro front clip with custom 4 link rear. It gets around 14 mpg highway....but with a heavy foot gets around 10 mpg. Not sure I would change much.
57 5700 LCF .... 468 Vortec BBC and 4L80E with 5.38 gears. Stock 19,500 GVW suspension. It gets 13 mpg when not towing and 9-10 mpg towing at around a total weight of 18,000 lbs. I am going to change to air ride suspension at some point.
59 3200 NAPCO....283, sm420 and 3.90 gears......all stock and not finished yet.
59 GMC F370 ...... 336 gmc v8 (pontiac), sm420 and 6.50/9.04 2 speed rear....stock 38,000 gvw suspension
___________________________
1959 Apache Short Fleetside,
1959 Apache NAPCO Long Stepside,
1957 3100 with 59 fleetside bed
1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370
1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF
1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker
Big Bertha Build
buggy5872 is offline   Reply With Quote
Old 05-08-2014, 06:42 PM   #13
S10Fan
Old Heap Driver
S-10 chassis, 307 sbc, 600 holley, TH-350, 3:08 gear, 2.25" exhaust with Thrush glasspacs, 215/75/15 Coker WWW, air ride with 4 corner control. The truck is a great cruiser, wouldn't change a thing.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 05-09-2014, 01:39 PM   #14
solidaxel
solidaxel's Avatar
I have one of each, but no inline 6, the best one is the LS and 4L60E.
Over the years I have tried them all, and the LS is by far the best "if you keep the hood closed". It is kind of hard to make a silk purse out of a pigs ear!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-11-2014, 07:54 PM   #15
waybad
waybad's Avatar
55 second series 235/5sp 8.5/308 31x10.5 tires gets 18 hwy and 12-14 city.. NO POWER AT ALL!! hills suck!!!!!! going ls soon i hope!!
Tinker
waybad is offline   Reply With Quote
