Old 05-02-2014, 01:13 PM   #1
1moretoy
static drop question?
Hey guys getting ready to do my brake conversion and need to figure out if I want bags or static drop. What is the lowest static drop I can do with stock inner front fenders and a c-notch in back with no rubbing. Not worried about having to widen the rear wheel tubs or modifying the bed floor a little as I still have to install it. If I can be at the same cruising height as having bags with good ride quality I think I would rather just do a static drop. I don't think its worth an extra $2500 just to be able to drop it a few more inches when parked. I will be ruining 20's all the way around. Post up some pictures with drop size and 20's if you can please. Thank you
1moretoy is offline   Reply With Quote
Old 05-02-2014, 02:07 PM   #2
tinydb84
tinydb84's Avatar
Re: static drop question?
Cant help you on the drop questions but I have ridden in both bagged and static dropped trucks and the bagged ones ride so much better.
You don't have to lay out with a crossmember but they do give you other benefit (steering, handling, etc).
David
Instagram: myfabguy
Old 05-02-2014, 02:29 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Lots of info about this subject.
Asked almost daily here on the board:
http://www.google.com/custom?domains...D%3A1%3B&hl=en
Keith
Convert to disc brakes.
