Old 05-02-2014, 06:43 PM   #1
low&slow
Is there a way
Wondering if there is a way to take out the tail light buckets from inside the bed without cutting up the bed itself. Is it possible or not?
low&slow is offline   Reply With Quote
Old 05-02-2014, 07:00 PM   #2
chiefcfd
chiefcfd's Avatar
Re: Is there a way
Not sure I understand the question. The tail light buckets come out on the outside.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 05-02-2014, 07:46 PM   #3
Tropical Snowstorm
Lurky lurky
Tropical Snowstorm's Avatar
Re: Is there a way
I did it less than a week ago and just took the two screws out of the plate and pulled them through the cut out in the bed side. It was a tight fit but tape on the bodywork and a little prying with a pocket screwdriver and they were out.
Tropical Snowstorm is offline   Reply With Quote
Old 05-02-2014, 10:17 PM   #4
low&slow
Re: Is there a way
When you take the tail light lenses out, there is a place inside the bedside that the tail lights sit in.
Thanks. I'll have to check mine out.
Old 05-03-2014, 12:30 AM   #5
Tropical Snowstorm
Lurky lurky
Re: Is there a way
I should be able to post pics early next week if you don't get it before then. It's all apart right now.
Old 05-03-2014, 05:09 PM   #6
low&slow
Re: Is there a way
Thanks I'd really appriceate that
Old 05-03-2014, 05:19 PM   #7
69chevytrucker
69chevytrucker's Avatar
Re: Is there a way
Ya the buckets come out there just screwed in undo the screws and they pop right out
69chevytrucker is offline   Reply With Quote
Old 05-03-2014, 05:22 PM   #8
69chevytrucker
Re: Is there a way
I took mine out so I could weld over the chrome strip holes so I didn't have to have the chrome around the lights
Old 05-10-2014, 08:21 PM   #9
Tropical Snowstorm
Lurky lurky
Re: Is there a way
Sorry it took me a week, the truck is at my dad's house.
Take out the two screws in the housing out, then I gently pried on the bottom and pulled it out at an angle.
Then I had enough room to get my fingers under the bottom of it
It comes out, just barely in the cut out for it
Then I unplugged the wiring to the bulb.
End result.
Hope that clears it up for you...
