Old 05-02-2014, 10:18 PM   #1
k_n_browning
oops need some help
Ok what happened?2 1/2 dropped spindles.I used the springs that was on the truck.I thought the springs were standard with a little sag.But there straight and the same length.And uncut.So what spring would I need to fix this mess.Name:  100_1092.jpg
k_n_browning is offline   Reply With Quote
Old 05-03-2014, 01:03 AM   #2
oldschool18
oldschool18's Avatar
Re: oops need some help
I don't see whats wrong.........unless you didn't think it was going to drop that much.
_________________________________
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Members Met......2003Silverado (Dave)
oldschool18 is offline   Reply With Quote
Old 05-03-2014, 01:09 AM   #3
Willys47
Willys47's Avatar
you need one more lug nut as far as I can tell.
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 05-03-2014, 07:59 AM   #4
k_n_browning
Well after cutting out the rear and dropping it on the bump stops.it has less suspension
Travel on the front.The wheel is hitting on the inner fenders.So the truck need to come
up some.So how much would the stock spring lift it up?The springs that were on the truck were not installed right.So I have know idea what the ride highth was if they were in properly.
Old 05-03-2014, 10:51 AM   #5
oldschool18
if your truck is really bouncy in the front end then you need some new shocks, it looks like you got a couple inches between your tire and inner fender now.
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Old 05-03-2014, 11:54 AM   #6
k_n_browning
Right now no shocks and its only about 1/2" to the
inner fender.
