Old 05-03-2014, 01:01 AM   #1
wilberweb
wilberweb's Avatar
55 chevy 3100 rear leaf spring problem
Hi, Guys
I just started on my rear leaf springs. I'm rebuilding the springs with all new bushings,shackle kit,new pins.My question is How to get the rear leaf spring mount bushing out? I cant seem to get an Idea on how to remove it.
I tried to get it out with a A-arm bushing remover tool with a little modification but it wont budge.I tried smacking it with a hammer. Any suggestions would be great.
Thanks for the help
-Larry
wilberweb is offline   Reply With Quote
Old 05-03-2014, 12:06 PM   #2
18tahoe
Re: 55 chevy 3100 rear leaf spring problem
What I had to do was get a punch and hit toward the frame, then use a torch to cut part of, hit the rest through. I can't remember if I used a little heat or not, maybe some one else will chime in.
18tahoe is offline   Reply With Quote
Old 05-03-2014, 12:33 PM   #3
wilberweb
wilberweb's Avatar
18tahoe,
I tried hammering with a punch, its in there tight.I haven't heated it up yet. I thought I may get some other Ideas.I was reading my 55 manual it shows a tool that removes this kind of bushing I cant seem to find that exact tool.
I maybe able to build one.I may need to heat it up if all else fails.
Thanks for the reply.
-Larry
Old 05-03-2014, 01:27 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
There is a tool for it but I doubt you could find it anywhere. The other option is heat and a steel punch that just fits the ID of the busing hole and heat and hammer it out.
something like this would work with heat
http://www.ebay.com/itm/48-56-Ford-F...9eeccc&vxp=mtr
dwcsr is offline   Reply With Quote
Old 05-03-2014, 01:56 PM   #5
Stepside Jim
Hi wilberweb, I just removed mine 2 weeks ago. I started with the angled punch idea but quickly realized the bushing is steel vs brass or bronze.
I didn't want to heat, no special reason, I just didn't want to.
I didn't want to try to cut it out, I usually end up cutting into something I don't want to.
I am fortunate to have an old lathe. I took a piece of 1" solid bar and cut.
The small step keeps it centered, the second step is a few thousands smaller than the outside diameter of the bushing. Worked perfect, big hammer and they came right out.
I have the new bushings in the freezer right now, I'll use the same tool for installing the new ones.
I see you mentioned making your own, perhaps this will help give you some ideas. Jim
My 57 Chevy truck build.http://67-72chevytrucks.com/vboard/s...d.php?t=541132
Stepside Jim is offline   Reply With Quote
Old 05-03-2014, 02:29 PM   #6
wilberweb
wilberweb's Avatar
Thanks guys,
I appreciate all the suggestions. I think Ill be making a tool then.
-Larry
Old 05-03-2014, 03:20 PM   #7
OrrieG
OrrieG's Avatar
If you don't have a lathe a yard sale find deep socket of the same diameter will work too.
OrrieG is offline   Reply With Quote
Old 05-03-2014, 04:27 PM   #8
wilberweb
wilberweb's Avatar
Thanks Guys
Your awesome!!! I got it... Drove it out with a hammer. I re- installed it with the A-arm bushing press from harbor freight tools.
-Larry
Old 05-04-2014, 01:03 AM   #9
wilberweb
wilberweb's Avatar
Hey all,
Thanks for the advice worked great here is how it turned out.
-Larry
Old 05-04-2014, 10:34 AM   #10
mark '87 930
mark '87 930's Avatar
Looks great Larry. i did mine a few months ago and had the same dilemma as you. I ended up hammering the old one out with the old pin screwed into it. I heated it up and gave it a few smacks with a mini sledge. Came out quite easily.
I will say that the trucks rides quite a bit better now too with the refreshed rear suspension.
mark '87 930 is offline   Reply With Quote
Old 05-04-2014, 11:53 AM   #11
wilberweb
wilberweb's Avatar
mark '87 930,
Thanks mark
I just smacked it out with the pin as well.At first it looked like you needed a special press.
So the first thing I did was get on this forum and ask. Its nice having this kind of knowledge in one place.
-Larry
