Old 05-03-2014, 01:23 AM   #1
solidaxel
solidaxel's Avatar
Lean bank 1 and 2
Started the truck, put it in gear, and it sounded like I was running out of gas, no power limped around the corner floored a few times and it cleared up!
My first thought it felt like water in the fuel, cleared up and the code said;
Lean on Bank 1 and Bank 2
P070??
Is this normal, no more problems, I cleared the codes, and all is working fine.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-03-2014, 10:06 AM   #2
littlevictories
Re: Lean bank 1 and 2
that's weird. fuel pump acting funny? you got a gauge on it?
one of the first things after the initial fire was to change the filter. i figured there would be tons of debris from the build process and wanted to get that out of there asap.
littlevictories is offline   Reply With Quote
Old 05-03-2014, 01:48 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Cleared up when you went wot?
Low fuel pressure; caused by either bad fpr, pump problem, restriction, low voltage to pump, or even bad pickup location.,
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-03-2014, 03:11 PM   #4
solidaxel
solidaxel's Avatar
YES, with WOT, it is starting to run rough when first start, but will clear in a minute or less. It has done it three times this AM after stopping and turning off the engine.
The entire fuel system is new including the fuel regulator, except the injectors and fuel rail, BUT they were cleaned and flow tested and there are no leaks.
I am going to put a gauge on the fuel rail and look for pressure before I start the next time
LS 3 4L70E
Old 05-04-2014, 12:36 AM   #5
littlevictories
lemme know if you need a -6 AN fitting with an 1/8th npt for a pressure gauge. i bought a **** ton during a drunk ebay session, lol. i tried to give them away on ls1tech but people kept giving me crap for charging shipping lololol
Old 05-04-2014, 04:45 AM   #6
kevmac
kevmac's Avatar
Man, if I had a nickel for every time i did that, I'd have 8 nickels!!!!
kevmac is offline   Reply With Quote
Old 05-04-2014, 09:31 AM   #7
solidaxel
solidaxel's Avatar
Will it attach to he schreader valve?
LS 3 4L70E
Old 05-04-2014, 10:21 AM   #8
littlevictories
naw, it goes inline with the AN to push-lok fittings…if you're using AN fittings
Old 05-04-2014, 10:22 AM   #9
littlevictories
here's my million dollar idea
a breathalyzer on your phone that prevents you from ebaying or calling ex girlfriends if you're over a certain amount.
Old 05-05-2014, 04:57 PM   #10
yossarian19
Check fuel pressure with key on, when you start the engine & when you drive it (if possible)
Also,
Read off your air mass meter's measured flow & compare it to what you find with google search.
"Over my head"
1957 Chevy 3200, big rear window & 6 lug.
Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina.
yossarian19 is offline   Reply With Quote
Old 05-05-2014, 06:38 PM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
One of these?
Daddy likes free parts, and loves blue fittings. If you wanna toss one in a cheapy envelop or something, I'lll kick you the shipping cost.
Old 05-05-2014, 11:11 PM   #12
69sinker
69sinker's Avatar
Hey man I'll take one! (Breathalyzer that is). Awesome idea, run with it, there's lots of us drunks that would buy one off of eBay. I'll take mine with the " bosses phone number blocker" option if available.
My 69 cst lwb 2wd LS1 swap 5.7/4L60e build
http://67-72chevytrucks.com/vboard/s...d.php?t=589869
69sinker is offline   Reply With Quote
Old 05-09-2014, 05:40 PM   #13
kevmac
kevmac's Avatar
Sign me up!!
Old 05-10-2014, 06:37 PM   #14
solidaxel
solidaxel's Avatar
Update,
For the past week it has been running fine, could have been a bad load of fuel, it has not missed a beat since.
LS 3 4L70E
