Power brake conversion ? Factory stock booster 1966
Have factory power brakes on a '66. Already converted to disc front can I use factory '66 booster with a '72 master cylinder an proportioning valve from the '72. Just curious if master will bolt up an work on stock booster
Never Ending Projects
Re: Power brake conversion ? Factory stock booster 1966
You should be able to use a '72 MC that was for a power brake application. Should bolt up without any issues.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
![]() Join Date: Sep 2009
i used the stock 64 booster with a 72 master for disc brakes worked good untill the booster went out
60-66 Nut
![]() ![]() Join Date: Mar 2007
You will want to check to be sure that the intermediate pushrod is the correct length for the master cylinder.
