gauge help
i bought a set of gauges yesterday from the swap meet and went i got home i notice the circuit panel is broken. i know i can buy a new printed cicuit from lmc for $40 but was wondering if the is repairable before i spend the money. i have heard it can be soldered, i also heard that it can be repaired with a piece of aluminum foil and them gone over with nail polish. anyone have any other tips for the repair? also its on the #7 pin colud anyone tell me what that pin is used for. thanks
![]() Join Date: Mar 2012
Re: gauge help
i would just invest in a new one saves from having a eletrical short or a fire later on
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
Active Member
![]() Join Date: Jul 2007
Re: gauge help
Best thing, as mentioned, is a new one but I fixed a land like that on my truck some years ago. I cleaned it off (burnished) to remove the tarnished part. Main thing is to make sure it hasn't burned through the land. In some cases you can use a pencil eraser to clean it up.
Then clean all the lands where the areas are tarnished but don't use finger nail polish. It may not make good contact and finger nail polish is flammable. Definitely would start a fire then.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Re: gauge help
The no. 7 pin is for the grounds for the dash gauge lights. It is fed by a black wire in the cluster plug and the copper strip is grounded by a small screw mounted through it to the cluster panel. There are a couple of the screws through the copper strip so depending on where the break is, the lights the lights may still work.
The orange wire in the diagram is the ground wire and it is right off the 7 pin. The circular dot just to the left is the first ground screw and the other dot over to the far right is the other one. All you may need to do is run a separate ground wire from the cluster to the cab dash. Just make sure the cab is grounded.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Msgt USAF Ret
Re: gauge help
Ok I see the picture in your first post, and the break is right at the 7 pin. You should be able to just run a ground wire to the cluster to one of the two screws and the lights should work.
Or, You could just solder across the break at the 7 pin and use the black ground wire to ground the lights. I think I would do both but once you complete the solder, cover it with some insulation. Black Silicon should work good.
Re: gauge help
Vettevet I'll try both option just incase 1 fails. Thanks
#7 | |
Active Member
Re: gauge help
