![]() Join Date: Apr 2013
U-Joint and Keyed Shaft from a 68 K20, PTO
For sale is a PTO Shaft and U-Joint removed during a partout from a 68 K20. The shaft is 39 inches in length and the Key’s on both ends are welded into the keyway. The U-Joint moves freely and the grease fitting appears to work also. The only numbers that I can find, are on/in the U-Joint cast… “0502 AC”
Asking $50.00 not including the shipping cost – Weight is approximately 7 Lbs. Local pickup is also available. |
| Bookmarks |
