Body Measurement Spec's
Looking for a spec sheet on the 69-72 blazer, I've been searching online now and cant seem to locate one. Im looking for a collision repair type thing, need oem specs for door openings pillar height ect.
I measured mine before we cut it up, but the truck was way out to lunch after being repaired multiple times. Thanks!! |
Re: Body Measurement Spec's
I've been doing bodywork for many years and never used spec. sheets on the body. Only frame specs. for straightening frames.
What I'd do is be sure the floor and rockers are straight and true with the frame then mount the doors to the pillars, align everything to the side panels and rockers then tighten the hinge bolts Tack weld them in place then remove the doors and finish welding it up.
Don aka Rocket_Man 72 K5 Blazer 454 CI 2002 Honda VTX 1800C |
i have this info dont know how to read it lol
thanks! ya not 100% sure on how to read that either, looks like the last one is of the body mounts, just not sure were the zero mark is. But it looks like Ive got it lined up pretty well now.
thanks again. |
