Inner fender help
Is the inner fender hard to put in on a 68 ? How do they go in and whats needed ? Pics would hlp
Navel Inspector
Good question. I have one on the passenger side of my 67 that will need swapping out as soon as I locate one that is without rust.
1948 Chevy Aerosedan GONE! I think. 1984 Cadillac Fleetwood Brougham Coupe WANTED 1967 IMPALA 1967 CST C10 Long Bed with a 283 |
67-72 Addict!
Inner fenders are usually pretty easy to install. I think there is about 7 bolts from what I remember, it's been awhile.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
jack up the truck, pull the tire/wheel, unbolt the old inner fender and bolt in the new one...
Be safe.....use jack stands !!!
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project Last edited by bigvinnie; 07-30-2003 at 07:25 PM. |
its all about the +6 inches
Don't even need to pull the wheel really.
The real PITA will be when 1/2 of your bolts break from the rust. ![]() |
USE JACK STANDS. I think if you turn the wheel a bit off center it makes it easier to get out. Really easy. Oh by the way, use jack stands.
TF Did I mention, use jack stands? |
