Old 05-05-2014, 03:10 AM   #1
chevyman70
4l60e problem or TPS, need help!
I have a 2003 5.3l with 4l60e on my c10. I drove it today and I noticed the transmission is downshifting hard when coming to a stop. I could feel 3-2, 2-1 downshift hard. Also, the 1-2 is delayed. The transmission was recently rebuilt, oil still clean and does not smell burnt. I check the tps sensor to see if it reads smoothly when I press the gas pedal, and it does, I think. with the engine off, the tps reads 18% and it moves to 99.6%, then back to 22% when I let go of the gas pedal for a few seconds, then it will return to 18%. When on, it idles around 3.5 to 5%, when driving I noticed it would return to 5%, but then fluctuates between 8-12% when I let go of the gas pedal and that is when it starts to downshift, or upshift 1-2 hard. I also notice that it seems like when the throttle cable or rod gets stuck on a carb when coming to a stop. It wants to continue even though I am not pressing on the pedal (drive by wire). So before I take it back to the tranny shop, I would appreciate it if someone can provide guidance. Thank you in advance.
chevyman70 is offline   Reply With Quote
Old 05-05-2014, 06:42 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 4l60e problem or TPS, need help!
DBW cars usually get b!tchy about TPS failures, so I'd think you'd pop a code pretty quick, and might even get a total-limp if the DBW doesn't want to work.
When your in neutral , how does the pedal "feel" in the rev range? Does the car stumble etc?
You may also have the lockup-issue thats common on cam-swapped dbw cars. The misfire counter needs to be offset/modified (value) to ignore false misfire caused by out of phase cam sensors on low-lsa. Lockup problems can also be caused by bad or poorly setup brake switches.
The bouncy tps data is probably just confusing more than helping, lets try to narrow down a couple factors and work from there.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-06-2014, 02:31 PM   #3
solidaxel
solidaxel's Avatar
Check and make sure the o2 wires did not get pinched between the engine and transmission, when you installed the transmission
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-07-2014, 01:13 AM   #4
chevyman70
funny thing you mentioned O2 sensors. While I was looking at the tps sensor, I noticed the fuel system going from close to open back to close. At time the sensors were not isolating from .100 to .900 like they normally do. I drove it when it was doing this to see if it affected the shifting points, and it drove horribly. It finally set the MIL lamp on P0135. I reset it and the O2s started reading normally, and again drove it to see how it drove, and the shifting improved. I have Bosch O2s and I know they gave me problems on another vehicle I had. So I am going to change them out with Denso's to see if it improves.
