Old 05-05-2014, 05:25 AM   #1
TRUCKGUY
TRUCKGUY's Avatar
long arm or 4link?
I just purchased a 72 Chevy Lwb 2wd and I am planning on making it 4wd already have military 3/4 ton d44 front and rear with 4.10 gears I want opinions should I do long arm suspension front and rear or 4link? The truck is gonna be just for show I'm talking 44" tires etc i want the bottom of the door 5 foot from the ground (or close) any and all opinions and advice is appreciated!!!!
Dan.
55 F100 panel truck project
64 350/th400/10bolt short fleet
66 F100 302/C6/9" short fleet
67 IH 4x2 304/t984speed D44 373 locker lwb box
67 IH 4x4 304/t98 4speed/d44/d60 4.10'slwb box
67 IH Travelall 4x4 304/t98 4speed/12bolt/10bolt
81 2wd short fleet current build!
83 350/700r4 short fleet
88 k5 12" lift 3/4 ton swap mud toy
96 Dodge 3500 CUMMINS/5speed/4x2
97 Pontiac Trans Am WS6/LT1 383/6speed/T-tops
TRUCKGUY is offline   Reply With Quote
Old 05-06-2014, 11:35 PM   #2
andrewmp6
Re: long arm or 4link?
With 44s you need 1 ton axles beefed up or 2.5 ton rockwells if you want to drive it hard.A 4 link front and back would be better to use.
andrewmp6 is offline   Reply With Quote
Old 05-08-2014, 03:31 AM   #3
TRUCKGUY
TRUCKGUY's Avatar
Well these d44's are 8 lug military full floaters I know the ring and pinion isnt no stronger but its just gonna be a cruiser I don't see no reason why they wouldn't work.... Any ideals on where I could look to get some ideals on building a 4 link set up?
Dan.
Old 05-08-2014, 04:38 AM   #4
andrewmp6
dana 44s are good tell 37s something will give out on them no matter what lug they are.A dana 60 beefed up is only good tell 44s.A k5 blazer its 3 link front 4 link rear http://www.pirate4x4.com/forum/chevy...zer-build.html
Old 05-08-2014, 07:30 AM   #5
ryanroo
ryanroo's Avatar
There are no hard and fast rules to tire size limits on axles. you can surive on a 44f and 44" tires. i would swap it to a 60f personally but with the 44 just expect to have a shorter service life on about every wear part on the thing. the military doesnt have any different axle than the civilian world, so that is nothing extra. if you do any sort of wheeling with it, andrew is right. it will explode its guts all over.
if you are new to fabrication or suspension, i would be careful about doing custom suspension. it needs to be designed and built correctly so it is safe for you and anyone around you. i dont know what you mean by long arm. if you build it tall enough for the rockers to be 60" from the ground, there is no way you can run anything short for links. there will be a lot of custom work to get a geometry on the suspension that is usable and safe
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 05-08-2014, 09:20 AM   #6
TRUCKGUY
TRUCKGUY's Avatar
Yeah I realize its gonna be a long term build and the truck will never leave the black top when I'm done.... Just going for looks here
Dan.
Old 05-10-2014, 03:38 PM   #7
Prerun71
Prerun71's Avatar
what do you mean when you say "long arm" are you talking a trailing arm setup ? which due to the panhard or track bar is still considered a link style suspension. it's just 3 link vs. 4 link.
Prerun71 is offline   Reply With Quote
