Old 05-05-2014, 01:07 PM   #1
62step
Tearing down the Stepside bed..
Hey everyone
I am about to send my bed off to get soda blasted and I was wondering whats a good way to take the stepside fenders off? I noticed they are a little rusty and what not, but I want to take the fenders off so they can blast behind that seem..
Should I try with a handheld impact driver (one you hit with a hammer and turning at the same time), or should I get some nuts and weld the nuts on the end of the phillips head screw?
Once I get them out (if I get them out) do I just re-tap the insert with the correct thread, or will I have to replace the hole that it goes into...
Hopefully this makes sense... lol
Any advise will be appreciated!
Thanks, Mike
62step is offline   Reply With Quote
Old 05-05-2014, 01:14 PM   #2
1963c-10
1963c-10's Avatar
Re: Tearing down the Stepside bed..
Personally I'd just drill the heads out from inside the bed and install new nuts/bolts if they are that bad. Did mine a few years back and only took 1/2hr to do both sides.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 05-05-2014, 02:56 PM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
have you soaked them with PB Blaster??>I would soak them in that everyday for a week or more. that allowed m to remove a lot of screw that were fairly rusted.
Good luck!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-05-2014, 04:16 PM   #4
62 Barnfind
62 Barnfind's Avatar
I did the same to mine when I tore it down. I also used my die grinder to cut from the inside. It's faster to cut them out than trying to turn them.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 05-05-2014, 04:33 PM   #5
62step
Ok, so I will try to soak them with pb blaster, if nothing else fails and I have to cut them off, I can just replace with a bolt and nut, no certain fasteners or anything? Just correct size bolt and nut and washers?
Old 05-05-2014, 04:51 PM   #6
1963c-10
1963c-10's Avatar
Correct, there are no welded nuts. Just plain nuts and bolts will work. I do recommend stainless or grade 8 personally, but its all a preference. Originally they had clutch heads if you want the original look and if you get something with a larger round style head similar to the carriage bolts they are a little more user friendly if the truck is used. This way nothing catches the heads of the bolts when loading or unloading the bed.
Old 05-09-2014, 10:56 AM   #7
62step
Thanks everyone, I finally got them off. I had to get my 4.5" angle grinder out to hurry things up. I was using a small air angle grinder..
I'll probably go with some grade 8 bolts to put them back on.
Thanks again
