Old 05-05-2014, 02:03 PM   #1
siggyfreud
siggyfreud's Avatar
Help me identify this rear
Hey all,
Picked up this rear end yesterday. I was told it's from a 69 Suburban.
Overall the width appears to be the same as the Dana 60 in my 66, however the leaf spring perches are about 2" further inward, along with the shock mounts.
Can anyone confirm what this rear is from from a photo?
I'd like to order the conversion axles and start cleaning this up, but want to make sure the time is worth it on the rear.
Thanks!
siggyfreud is offline   Reply With Quote
Old 05-05-2014, 02:14 PM   #2
60-66
60-66's Avatar
Re: Help me identify this rear
On the front passenger side of the axle tube are the code letters that will tell you what gear ratio it came with, I can look that up or if you have a GM parts book, then theres a date cast into the center section. Hope this helps
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 05-05-2014, 02:47 PM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
My opinion only but I think its from a car.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-05-2014, 03:01 PM   #4
siggyfreud
siggyfreud's Avatar
Hmm. Well that could suck I suppose. Other than relocating the perches anything that would prevent this working in the truck?
Would the aforementioned numbers (by Member 60-66) give insight into what this came out of?
Old 05-05-2014, 03:06 PM   #5
60-66
60-66's Avatar
I assuming its 6 lug being 69 ?. Yes the letter code on the tube will tell you car or truck
Old 05-05-2014, 03:17 PM   #6
siggyfreud
siggyfreud's Avatar
Yes, it's a 6-lug. Planning on converting to 5x5 to match the front.
Old 05-05-2014, 07:37 PM   #7
60-66
60-66's Avatar
OK, I just bought a 1968 and a 1972 truck rear. Looks identical to yours physically. Yours is a leaf spring rear, not a coil spring. If you have a GMC leaf spring truck it will bolt in. Im confused that the pads are 2 inches further apart though ? Did you measure center to center ?
Old 05-06-2014, 12:29 AM   #8
siggyfreud
siggyfreud's Avatar
The pads are two inches closer together measured center to center than on the Dana 60. I'll remeasure tomorrow but if I remember right the Dana was about 43" and the 12 bolt was about 41".
Old 05-06-2014, 12:53 AM   #9
Captainfab
60-66 Nut
That is a 12 bolt from a '64-'72 leaf sprung truck. I'm thinking it is likely from a 4x4, which IIRC the springs are closer together on the 4x4's.
Old 05-06-2014, 01:51 AM   #10
siggyfreud
siggyfreud's Avatar
I believe you're correct. Now that you mention it I think it was from a 4x4. Is it the same otherwise? Mainly thinking axles. Will your disk brake brackets work?
Old 05-06-2014, 01:57 AM   #11
Captainfab
60-66 Nut
Yes, it is still a truck 12 bolt. I would verify the width or the length of the axles before you order them. Yes, either of my rear disc brackets should bolt right up.
Old 05-07-2014, 12:04 AM   #12
siggyfreud
siggyfreud's Avatar
Thanks Captain.
Here is an ID number I could after much dirt removing. Passenger side front/top. Do these mean anything to anyone?
Old 05-07-2014, 02:01 PM   #13
old cool
Hey Siggy.
I'm not sure if you and I have same rear. (You responded to me regarding "noises in drive line"
I too have 66 gmc, swb, inline 6, with Saginaw trans. The person I bought from was a gmc service manager and seemed to know his stuff. He said my rear end was Dana 44, open differential, 342.
Let me know if I can measure anything, or read any number. I will look at more closely. If you can post back or side photos it would help.
old cool is offline   Reply With Quote
Old 05-09-2014, 06:02 PM   #14
old cool
Since I have the smaller rear set up I'm prob not that helpful but I did see a casting number on the top pass side of differential (44 . 1)
also went to spicerparts.com and found lots of info on our differentials and ujoints. it cover parts and videos. the phone # is 800-621-8084. Since Spicer and Dana are a joint enterprise, they would prob know exactly what you have.
Old 05-09-2014, 07:01 PM   #15
siggyfreud
siggyfreud's Avatar
Thanks for the help. Did spicer make Chevy 12 bolts? The dana is what I took out, but the part number above is from the 12-bolt.
Old 05-09-2014, 07:32 PM   #16
old cool
as much as I'd like to help, I am not equipped to answer your question. I knew that Spicer and Dana were joint so I went to the Spicer site I mentioned to look up ujoint info. I also entered 44 dana in the search bar and brought up info ... I called them today and left message re parts and haven't heard back yet. I'm sure they would need a couple full time employees just to help us forum guys. Good to know they're out there. good luck.
