Old 05-05-2014, 04:42 PM   #1
Chris04
Chris04's Avatar
Help with what size rim to go with on rear of my 70 swb
Hey guys I'm super new to these trucks and was wondering if I could get some help? I got a 70 swb fleet side I currently have it lowered 4.5/5" in rear. My next goal is a set of wheels and I want to go wide as possible on the rear wheel basically I want the biggest lip I can get without having to cut any on my wheel walls or bed. I'm going to do the 5 lug disc break conversion all the way around then purchase my wheels. Problem I'm facing is I read somewhere about you could have your rear end shortened to 60" and run a pretty decent wide wheel on back. I'm pretty sure I have the longer 63 1/2 rear end I'm not 100% sure tho and guess it don't matter if I'm going to have it shortened anyway, so if I go ahead and get my 5 lug axles in and have the rear end shortened to 60" how do I know what back spacing to go with? Have any of you done this? Hope I
Explained it we'll enough! I just don't know what's the widest wheel I can go with on a 60" rear end. Any help appreciated guys
I'm looking for a wide wheel like this
http://i173.photobucket.com/albums/w54/skaylad/Mobile%20Uploads/image_zps83b597ce.jpg[/IMG]
I know you guys like pics so here is mine working on it slowly
Chris04 is offline   Reply With Quote
Old 05-05-2014, 10:34 PM   #2
Chris04
Chris04's Avatar
Re: Help with what size rim to go with on rear of my 70 swb
Anyone?
Old 05-05-2014, 11:20 PM   #3
70cst
70cst's Avatar
Here is a bump for you.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 05-09-2014, 02:02 PM   #4
68Stepbed
68Stepbed's Avatar
Find out which width rearend you have now, then we can help. It's hard to give an answer without knowing the correct specs.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 05-09-2014, 02:07 PM   #5
mr48chev
mr48chev's Avatar
The progressive truckers don't like my comments on those new style wheels but I think it looks great with the ralley wheels that are on it.
My ongoing truck projects:
Old 05-09-2014, 02:13 PM   #6
67 cst swb
67 cst swb's Avatar
Ok let me try to give a little assistance...
The 1970 and Older 6 lug rear axle housings are narrower than the 71-72 5 lug axle housing. Also, I have heard... that 1970 model can have either width axle housing, so yours being a 70 adds another degree of unknowns.
So it is difficult to answer your question...
Also... There are a few ways to convert to a 5-lug wheel as you mentioned. You can swap in the wider 71-72 5 lug rear axle housing assembly from another truck or you can buy after-market 5 lug axle that slide into your 6 lug narrower housing, which bring me back to the unknown issue of... if 1970 does really have both different width axle housing in that year... then which do you have?
So, as you can see its not that easy of answer/reply.
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 05-09-2014, 02:38 PM   #7
Chris04
Chris04's Avatar
I understand, my issue is I can't figure it out either I tried to measure from back side of drum to other back side of drum and it's right at 60" then I measured from back side of drum to where the u bolt goes around axle and it's like 8 1/2 inches. I saw a thread where they were telling to measure certain things but I didn't understand. So does any of the measures sound familiar. I'm thinking I got the 63 1/2 rear end!
Old 05-09-2014, 02:48 PM   #8
67 cst swb
67 cst swb's Avatar
I believe 63-1/2" would be the 70 and older measurement. If I remember correctly the 71-72 are 65" wide.
My Trucks:
