Old 05-05-2014, 05:34 PM   #1
Jamminjohn
transmission cooling
Sorry for the stupid question.
do you have to hook the transmission cooling lines?
if not can the be plugged?
thanks,
John
th350
SBC 350
72 k5 4x4
Jamminjohn is offline   Reply With Quote
Old 05-05-2014, 06:22 PM   #2
cleszkie
cleszkie's Avatar
Re: transmission cooling
I would strongly recommend it. The auto makers all have tranny coolers built into the radiators for a reason. Heat kills transmissions. Besides, it allows you to run a larger volume of fluid which helps with cooling too.
cleszkie is offline   Reply With Quote
Old 05-06-2014, 12:11 AM   #3
mcmlxix
Collector of Projects
mcmlxix's Avatar
Why don't you want to connect the lines? Missing lines? Radiator doesn't have a built in cooler?
A lot of people in the warmer states add an additional transmisison cooler besides running the one in the radiator. Being in Long Beach, I would not plug or bypass your factory cooler....
Rich
1972 K5 Blazer CST Click HERE
Old 05-06-2014, 12:53 AM   #4
87Skier
87Skier's Avatar
Don't plug them. Some transmissions send all fluid through lines, so if you plug them, you may kill the transmission.
If you just need to test the transmission you could connect them together, but definitely get a cooler in there unless you like rebuilding transmissions.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 05-06-2014, 11:15 AM   #5
Jamminjohn
yes, missing cooling lines.
And didn't realize my new radiator had the connections for the lines.
I will order the lines and hook them up.
thanks guys.
