temp guage sending unit?
Is there a 3/8 temp gauge sending unit that will work with the factory temp gauge?
The summit racing double hump heads on my engine are set up for 3/8". According to the summit tech line aftermarket gauge sending units will not work with the factory gauge. Thanks! |
Re: temp guage sending unit?
Not that I know of. It's pretty easy to drill the 3/8s hole out and tap 1/2 threads to match the correct sender. You can also put the sender in the intake.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
![]() Join Date: May 2010
See post 15 in this thread. He (brian mac) turns down the originals and rethreads them. I think he charged me something like $20.
http://67-72chevytrucks.com/vboard/s...d.php?t=484537 |
Thanks for the replies!
the Edelbrock intake location for it is right next to the water neck kind of tight, also its a used intake with a steel plug in it that may not come out. The heads are already on the block what about steel shaving getting in the water jacket when you drill and retap? I guess you could try to vacuum them out? |
yep, just tried to remove the plug, no dice, heating with a torch might do it but I'm not going to try it.
Just get a factory temp sensor and have it machined down.. I went thru those headaches a few months back..
