Old 05-05-2014, 10:35 PM   #1
sb69chevy
sb69chevy's Avatar
4-row radiator conversion support adjustment
Anyone have pictures of what your adjusted rad support looks like? How much will I need to take out? Trying to decide if I'm going to 3-row or 4-row radiator in the near future.
Thanks, guys.
1969 C/10 swb, 350, powerglide (daily driver)
2005 CRV (wife's ride)
sb69chevy is offline   Reply With Quote
Old 05-05-2014, 11:42 PM   #2
Fitz
Re: 4-row radiator conversion support adjustment
Thanks, guys.
Why mess with the Rad Support? Be Cool has a direct fit 4 row rad that is good to 700 HP with the electric fans. It even uses the stock lower rad mount and pads.
Fitz is offline   Reply With Quote
Old 05-05-2014, 11:47 PM   #3
LSUMurse
LSUMurse's Avatar
I don't know if this will help, but I installed a radiator from Autozone.
http://www.autozone.com/autozone/par...7011_266534_0_
It was too big to fit my old radiator supports, so I got some 4-row supports off the parts board and it installed just fine. I didn't have to change or cut anything except to cut out a little portion of the lip of the support (not sure the actual part) right below the radiator to accomodate for the longer length of the radiator support. I can't find out from the Autozone site if it's a 4 or 3 row and the counter monkeys are of no help, so I don't know if it's a 4-row. However, based soley on size, it fit without any other mods besides the small cut for the bigger supports.
It's not that I am apathetic, I just don't care.
If your life is a joke, it appears death will be your punchline.
LSUMurse is offline   Reply With Quote
Old 05-06-2014, 09:59 AM   #4
quick60
quick60's Avatar
I did exactly what LSUMurse did with a 4 row. I bought my rad mounts from Brothers I think. Dont like the look though because the have tabs for fan shroud that mine does not have. Will change out one day.
quick60 is offline   Reply With Quote
Old 05-06-2014, 10:47 AM   #5
Daddy Brim
Daddy Brim's Avatar
It is very easy. I used my die grinder with a cutting blade. Just cut the lip on the support bend flat, once you put the lower mounts on you will not even see it.
I'm sorry I called you stupid. I thought you knew already.
67 C-20 Custom Camper
68 Nova 396 it does wheelies
2005 Buick Century the one the wife drives
1989 Toyota Tercel to drive when I can't put gas in the first 2.
Daddy Brim is offline   Reply With Quote
Old 05-06-2014, 12:55 PM   #6
sb69chevy
sb69chevy's Avatar
Thanks for the info, everyone. I'll get a grinder and give it a shot!
Old 05-06-2014, 04:34 PM   #7
john
member #16
john's Avatar
All I did to mine was bend the lip over with vice grips.
john is offline   Reply With Quote
Old 05-06-2014, 05:24 PM   #8
sb69chevy
sb69chevy's Avatar
That sounds even better, John! I'll give it a shot in a week or so.
Old 05-06-2014, 07:01 PM   #9
sambudo
sambudo's Avatar
thats cool!
1968 C10, 250, L6 4spd OTF, Fleetside
Upgrades: Power Steering
.......................____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
sambudo is offline   Reply With Quote
