Old 05-06-2014, 12:08 AM   #1
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Name this relay
I was cleaning up the engine bay in my 71 by removing wires that don't do anything. I found some that aren't doing anything and they go to this relay. What are they for? What is does this relay do?
LOW DOUGH is offline   Reply With Quote
Old 05-06-2014, 12:19 AM   #2
1972SUPERSB
1972SUPERSB's Avatar
Re: Name this relay
It is your horn relay. Well maybe not its in a different spot.
Jeff
1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt
1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior
1972SUPERSB is offline   Reply With Quote
Old 05-06-2014, 12:31 AM   #3
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: Name this relay
It looks like the Speed Warning Dash relay to me and even seems to be in the right spot for it. Now the thing is you say its on your 71 and I am very certain the Speed Warning Dash wasn't an option after 1969.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 05-06-2014, 01:02 AM   #4
SS Tim
SS Tim's Avatar
Re: Name this relay
Located above your disconnected horn relay is the TCS (Transmission Controlled Spark) timing relay. As far as being redundent, that would all depend on how complete and functional your truck is. The system explanation is a little better in the 72 service manual than the 71.
SS Tim is offline   Reply With Quote
Old 05-06-2014, 01:16 AM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Name this relay
Copied from another thread.
Re: Transmission Controled Spark
TCS uses a speed switch in the transmission and an engine temperature switch to control a time-delay relay mounted on the inside of the firewall near the horn relay to turn on and off a solenoid valve that disables vacuum advance to your distributor.
Power is supplied by a brown/white wire that comes from the square fuse panel connector.
Two wires plug into the TCS solenoid valve (mounted on the intake manifold): brown/white & dark blue.
The brown/white and the dark blue wires then run through the firewall to the time-delay relay.
A black wire runs from the time-delay relay back through the firewall and connects to the transmission switch.
A second dark blue wire runs from the solenoid valve to a temperature switch mounted in the passenger side head.
The horn relay is below the TCS time delay relay and to the right, The red green and black wire harness goes to the horn relay.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 05-06-2014, 09:19 AM   #6
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Re: Name this relay
Thanks. I was just curious. My truck is not complete as in it's not original. It seems to have all been peaced together. I think the cab is a 72 because of the things a 72 had different from the other years.
Also I need to fix the horn button. That's why the horn relay is unplugged.
Old 05-06-2014, 02:15 PM   #7
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Re: Name this relay
Would this relay be on a six cly, 3 on tree truck? I think not. That's what my VIN calls for. I still have the clutch/brake pedal assembly under the dash. I bought the truck with a 350/TH350 combo in it.
Old 05-06-2014, 05:26 PM   #8
SS Tim
SS Tim's Avatar
Re: Name this relay
Why not? They were installed pretty much across the board in C10s due to vehicle gross weight classification. But to directly answer your question yes a 71 6cyl/3OOT truck would have had the TCS (or CEC) system.
Might want download a manual or two if you don't have them to more completely understand how your truck was built and what systems were used above the minimum required to run the engine.
An example of this would be if you have a functioning Neutral Safety Switch for you current trans installation.
* VIN/Model Decoders
* Power Team Charts (engine/transmission/gear ratio)
* Post Your Pickup SPID Blazer SPID Suburban/Panel SPID
* RTFM
... Read The Factory Manuals... download 'em here
Old 05-07-2014, 08:23 PM   #9
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Re: Name this relay
Yeah... the neutral safety doesn't work on my truck.
Old 05-07-2014, 08:23 PM   #10
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Re: Name this relay
Thanks for the info SS TIM.
