05-06-2014, 01:41 AM | #1 |
Brake booster vacuum
is it ok to run vacuum from rear of carb for brake booster?
05-06-2014, 02:22 AM | #2 |
Re: Brake booster vacuum
only if it is on the carb base - it must be a steady vacuum signal, not ported, regardless of truck rpm. That is why the factory used the intake manifold port location primarily.
05-07-2014, 01:48 AM | #3 |
thanks
05-07-2014, 10:01 AM | #4 |
If your carb has the large fitting at the rear of the base, yes that's good. Q Jets used that location with a large screw in flare fitting for a hard line to the booster.
1957 CHEVY 1/2 TON SHORT BED 1940 FORD 1/2 TON SHORT BED |
