Old 05-06-2014, 10:26 AM   #1
Jemo
Which brake switch are LS guys using?
I'm reading the instructions on the harness I intend to buy and it requires a 2 way brake switch. I think most use a mechanical brake switch and not the plunger style. I don't see how the plunger style can be retrofitted.
Thank you
'59 Big Window Fleetside
Jemo is offline   Reply With Quote
Old 05-06-2014, 07:22 PM   #2
ghettoluxury
ghettoluxury's Avatar
Re: Which brake switch are LS guys using?
Use one from a mid 80's C10, they have the switch with both a normaly open and a normaly closed circuit. It is a plunger style and should bolt in place of your old one.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 05-07-2014, 07:35 AM   #3
Jemo
This is something I'm having trouble picturing....how to mount the later model brake switch. I have a Watson mechanical brake switch right now which mounts to the firewall and has an arm on it so when the brake pedal is pushed, it lets tension off the arm. The plunger style wouldn't work with this and not sure how to make it work. Build some type of bracket? Any pics would help me a bunch.
Old 05-07-2014, 10:00 AM   #4
Iceburgh
Iceburgh's Avatar
new to the LS stuff....
educate me as to why the LS set up needs any feedback to or from the brakes. I have not planned on this at all.
Thanks in advance
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
Old 05-07-2014, 10:08 AM   #5
Jemo
oh...it needs it for the torque converter lock up.
"When using a 4L60E or 4L80E transmission you MUST have a two-position brake switch. These are necessary to allow proper function of the TCC. The brake switch should be closed (electrically connected) when the brakes ARE NOT being applied and open (not electrically connected) when the brakes ARE being applied"
http://www.psiconversion.com/tech_ar...structions.pdf
Old 05-07-2014, 10:10 AM   #6
Jemo
I just realized there is a LS forum. I'm going to re-post this question over there.
Old 05-07-2014, 10:40 AM   #7
Iceburgh
Iceburgh's Avatar
Thanks for the PDF
1953 suburban build
Old 05-07-2014, 11:25 AM   #8
ricott
I used a 2000 Camaro brake switch in my 1966 GTO. It has two circuits, when the brake is depressed, the plunger extends - one circuit is energized and the brake lights come on, and the second circuit is interrupted, which causes the Torque converter to unlock (or, in my case, the cruise control to disengage - I have a six speed Manuel Tranny). Hope this helps.
Ricky
ricott is offline   Reply With Quote
Old 05-07-2014, 12:18 PM   #9
Kabwe
Certified Car Nut
Kabwe's Avatar
This is the one I'm using
You can get it here http://secure.ultracart.com/catalog/PSI/KIT-1002.html its 21 bucks.
Kabwe is offline   Reply With Quote
Old 05-07-2014, 01:37 PM   #10
_Ogre
_Ogre's Avatar
if your using the stock brake switch and pedal it is very easy to add a relay into the circuit
i need this for the 700r4 and cruise control kick out
shop air compressor timer
Old 05-07-2014, 07:05 PM   #11
Painter D
Painter D's Avatar
PSI conversion sells one for around 16$ or so. That the one I used
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 05-07-2014, 10:57 PM   #12
ls1nova71
ls1nova71's Avatar
I answered this question the OP posted in the LS swap section with the same relay set up, but if you're going to use the relay, your 12v going into the relay should be an ignition hot 12v, tapping into the hot side of the brake light switch will have the TCC powered up all the time since the brake light power is a constant hot. You may not have a problem running it that way, but you also could, and it could be hard to trace a parasitic drain. Hope this helps.
Also, if I read it right the OP is mounting the master cylinder under the floor, and most switches are not designed to live very long in a wet environment, so unless you plan to never drive the truck in the rain, you would be better off to use the lever switch that's made to be mounted under the truck and just wire in the relay for the TCC.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 05-08-2014, 02:01 PM   #13
_Ogre
_Ogre's Avatar
thanks for that info lsnova71, i do have a drain but i believe it is the security system, but you have me thinking...
my truk needs to run every 10 days or the battery will not start truk, again i think it's the alarm system but will look at the additional drain.
