Old 05-06-2014, 03:33 PM   #1
61K10
61K10's Avatar
hyd clutch bleeding
any tips on bleeding a hyd clutch with everything new. bench bleed the master of course. piston in slave all the way in to start? how much play in the throw-out bearing arm to start? this is on my 61K10.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 05-06-2014, 05:06 PM   #2
Redcap
Re: hyd clutch bleeding
Bench-bleed both. Install. Re-bleed. Enjoy.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 05-10-2014, 06:02 PM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
If I remember correctly, you will want the slave piston pushed in - I had quite the battle getting the system working that I swapped into my truck.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-15-2014, 10:34 AM   #4
argonaut
argonaut's Avatar
I just bled the mc first, then hooked up the line to the slave and bled it the rest of the way. I also pumped the slave side a few times which pushes air bubbles back out through the master. With a hydraulic clutch there is no pre load to worry about.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 05-16-2014, 12:59 AM   #5
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
I've had good luck on external slaves by bench bleeding the entire assembly. With the master in a vise I run the line vertically down to the slave cylinder and cycle the slave by hand slowly getting all the air out. Once air bubbles stop coming out the master I extend the slave one last time and let it compress with the bolts as I install it. This pushes any last bit of air up to the reservoir.
This is a simple way and has worked great for me for the slaves that don't have a bleeder.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
