Old 05-06-2014, 10:15 PM   #1
68chevystepside
68chevystepside's Avatar
Exclamation Rec: Where to buy control arms
I replacing my front end suspension and brakes on my 68 stepside with parts from ece. During the removal of my old suspension i found out my upper and lower control arms were not reusable because the were so old and would not separate from the drum spindles. Since ece does not sell them so i found some from no limit engineering and from truckandcarshop.com. My question is have any of you purchased control arms from either one of these companies or do any of you have another place you recommend? thanks.
68chevystepside is offline   Reply With Quote
Old 05-07-2014, 06:25 AM   #2
PGSigns
PGSigns's Avatar
Re: Rec: Where to buy control arms
Are they rusted out? If not getting the ball joints out of the spindle is not a big deal. If they are still solid I would rebuild them. Also there are a bunch of us who are running the 73 to 87 control arms with the better bushings.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-07-2014, 08:07 AM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
The control arms you speak of are custom and are not cheap. If you want a corner slicer truck, then those might be what you need.
If you want just daily driver, then as PGSigns said, go with a 73-87 1/2 ton upper and lower. those can be had at any wrecking yard pretty cheap, blast, paint, install.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-07-2014, 08:32 AM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
There is absolutely no reason in the world to buy new control arms because you can't separate the old ball joints. None. Zip, nada.
Any decent mechanic shop in your town can pop them loose for pocket change. Just throw them in your car and run them up there. They'll bang them apart with an air hammer and fork attachment.
Worst case imaginable, you have to take a grinder and cutting wheel and cut the studs off the ball joints. Then you'd be left with a basic ball joint replacement job. Just fold the arm up as far as possible and run the cutting wheel in between the spindle and ball joint and slice through it.
Do what you want, but if you spend money on different arms for the reason you stated above, it's wasted money.
Old 05-08-2014, 04:50 PM   #5
Snoopy's C10
This was useful. I am in the same boat and now I'm sticking with factory and just rebuilding them.
Snoopy's C10 is offline   Reply With Quote
