Old 05-07-2014, 09:17 AM   #1
jmj4
jmj4's Avatar
Vacuum Gauge Installation
I'm trying to install a vacuum gauge and need photos or a description of how the hose runs from back of the manifold into the cab. I know it would have originally been a steel line (i'll be installing a hose), but where does it penetrate the firewall? An existing grommet or new hole?
Seems I saw a write up at one time detailing the installation, but I've searched and can't come up with anything.
1970 GMC Custom 1500 SWB 307/TH350 3.73 Positrac
jmj4 is offline   Reply With Quote
Old 05-07-2014, 10:37 AM   #2
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: Vacuum Gauge Installation
This thread may help you some. There is a grommet in the firewall behind the distributor toward the drivers side and wires and the oil pressure gauge line goes through it. That is where I am going to run mine through.
http://67-72chevytrucks.com/vboard/s...10#post6526010
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 05-07-2014, 11:14 AM   #3
jmj4
jmj4's Avatar
That's what I was looking for! Thanks.
Old 05-07-2014, 11:41 AM   #4
Already Gone
Where are you going to get your vacuum from, the intake manifold?
Old 05-07-2014, 11:45 AM   #5
jmj4
jmj4's Avatar
yes behind the carb.
Old 05-07-2014, 12:02 PM   #6
Already Gone
I had single tree fitting in my intake and ordered the one in the attachment which should make for a clean installation. I plan to use steel under the hood and once through the firewall use rubber hose under the dash.
https://www.paragoncorvette.com/p-35...m-fitting.aspx
Old 05-07-2014, 12:10 PM   #7
jmj4
jmj4's Avatar
i'm going to use the same fitting.
Old 06-25-2014, 08:59 PM   #8
HIGHWAY BY THE SEA
HIGHWAY BY THE SEA's Avatar
Ref. the part pictured in post #6,
If I get one of those would it be possible to hook it into the carb intake on my inline 6 where there is an angled "plug screw" then directly to the VAC gauge? Or does this VAC gauge HAVE to be "T"ed into everything?
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside
GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=584617
PROJECT JIGSAW 1967 GMC C3500
GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion
HIGHWAY BY THE SEA is offline   Reply With Quote
Old 06-26-2014, 12:06 AM   #9
Already Gone
I dont see why you couldn't go from the fitting to the vacum gauge. The fiting in picture 6 is from my BB intake manifold.
Old 06-26-2014, 12:42 AM   #10
HIGHWAY BY THE SEA
Since I posted this earlier today I have since hooked up the VAC gauge to a nozzle (that was plugged with a rubber cap) on the bottom front of my carb's base. The VAC gauge works now, but I hope this is an OK place to attach this. It seems everyone uses the "T" method to install these.
Old 06-26-2014, 09:52 AM   #11
67chevemall
67chevemall's Avatar
Just make sure you use the bottom feeder of the carb so you get your reading for engine vaccum and not the carb vaccum.
I used hose all the way and it works great!
The TRU 7 gauges.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
