05-07-2014, 10:04 AM | #1 |
How hard to go from BBC to SBC?
OK so I am in a bind here. We recently purchased a new to us 1968 suburban for my wife. Well within two days of buying it heard a little tick/ knock. The folwoing week took it over my mechanic and he said it sounded more like just the valves needing a little adjustment. Needless to say the tick went away but the next day it was back again and took it back over there. He took the thing apart and found a bent pushrod. Told him to take his time and now that he has the whole thing apart there is wear on the cam bearing and has not taken the bottom end apart yet as I told him to stop. MY question is I can get my hands on a nice SBC with all accessories pretty much to drop in but am curious what is involved in swapping over? The SBC will have headers on it so i guess im wondering if it will just be the mounts that will be different. The original engine in the suburban seems to be an 1970-1971 396 according to the stamping on the heads and block. I simply dont have the money right now to do a full rebuild on the BBC. .
05-07-2014, 11:15 AM | #2 |
Re: How hard to go from BBC to SBC?
What trans is in the burb now? I'm doing the exact reverse of what your wanting to do. I'm going from small block to big block. So far it's pretty much bolt in other than the crossmember fitment ( a previous owner had moved it it seems). You'll definately need exhaust work, power steering is different if you have that.
Which if you do have p.s. And want to part with the pump/ bracket let me know I need one.
61 apache |
05-07-2014, 11:56 AM | #3 |
The trans in there now is a 700r4 I beleive. I know its no longer the TH400. As far as power steering how hard woud it be to mount the current set up on the sbc? or would it be crazy to drive it without p/s?
05-07-2014, 01:51 PM | #4 |
To mount your power steering to your small block you'll just need the accessory brackets. They are different on a big block/ small block I found out.
Your trans should bolt right up, not sure on linkage issues though as mine is a 4 speed.
61 apache |
05-07-2014, 02:02 PM | #5 |
Thanks for your help. Now the last question would be are the engine mounts the same?
05-07-2014, 02:40 PM | #6 |
Are your engine mounts clam shell or flat? Either way I believe they are the same. Mine bolted right on my 454 and then bolted down in the same spot. (Mine had the flat style)
61 apache |
05-07-2014, 03:13 PM | #7 | |||
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
05-07-2014, 05:27 PM | #8 | |
05-07-2014, 05:41 PM | #9 |
I've seen shavings on cam bearings from installing/removing the cam. When they wear you don't find shavings (they would get smeared around the bearing by rotation). I'm not saying anything bad about your guy, but it wouldn't be the first time a collapsed lifter got adjusted to a bent pushrod. Cam bearings don't cause ticks, they are purely a rotational plain bearing that doesn't usually create issues. Your big block swap would be the easiest if you choose to go that way. Are you doing the swap?
05-07-2014, 09:47 PM | #10 | |
05-08-2014, 12:04 AM | #11 |
I would take you up on it if I were a couple thousand miles closer!
05-26-2014, 11:59 AM | #12 |
Could be also that the first valve adj he did not notice the bent rod, then caught it the second time around after it bent some more
05-29-2014, 09:09 PM | #13 |
So, what ever happened with this?
05-29-2014, 09:32 PM | #14 |
Kept the 396/ 402.....my mechaic that was working on it took it all apart and said the bottome end all loked good and aside from the heads having a little carbon build up it all looked good. SO got a new cam, can bearings valvels, rocker arms, etc and he is giving me a warranty in writing that there was no other damage done and everythign else is ok. Since I had aleady planned on spending a certain amount originally we came to an agreemt to have the work done for said amount since I am a regular custoemr of his and have brought him and continue to bring him business. Also let him take his time with this so he would be in no rush and work on it on slow days. I stopped by today and he said the engine should be back in tomorrow or saturday. Keeping my fingers crossed everything works out.
