Old 05-07-2014, 10:11 AM   #1
Jemo
How did you mount your 2-way brake switch?
I didn't realize there is a LSx swap forum so I already posted this.
http://67-72chevytrucks.com/vboard/s...=1#post6663271
Want to see how others have mounted the 2-way switch on trucks with a through the floor brake pedal. Thanks.
'59 Big Window Fleetside
Jemo is offline   Reply With Quote
Old 05-07-2014, 10:28 AM   #2
ls1nova71
ls1nova71's Avatar
Re: How did you mount your 2-way brake switch?
That brake switch won't live long under the cab, since it's not designed to get wet. It will work for a while, but why do that if you already have the lever style switch? Just use the lever switch (which I'm assuming is similar to a 48-53 chevy truck brake switch? That's what I have on my car) and run a relay off of it. Hook the #85 to the side of the brake switch that's hot when the brakes are applied, and hook #86 to ground. Then hook your ignition power to #87a and the other side, #30 will go to the TCC wire in the PCM. Then you'll have power to the TCC and when you step on the brakes, the relay will be energized and open the circuit and will function exactly like the 4 prong switch.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 05-07-2014, 11:54 AM   #3
Jemo
ok, thanks very much. Here is the switch I have:
http://www.hotrodhardware.com/index....585/prd585.htm
I'll give it a try.
Old 05-07-2014, 01:29 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I'll give it a try.
Does the plunger-style switch not have a place to fit on your truck? I've never seen those mechanical ones used, except in a couple old hotrods for a 700r4.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
