Old 05-07-2014, 11:17 AM   #1
suburban99
suburban99's Avatar
New to the forum, just hauled a '62 c10 fleetside home.
Hey all bought a '62 c10 long-bed fleetside and hauled it home on my trailer.
Last time on the road was 2005. Previous owner(s) replaced the floor pans, installed a 1978 chevy front end 5 lug disc, a 10 bolt rear end, a 307 Oldsmobile with a 200R4 auto tranny.
I do not think the truck has run since these mods. Truck is very straight and has little rust. Back end of frame coated with POR15. The hot rod shop I bought it from was going to use it as a shop truck but ran out of space.
What do you think about the drive train? I know 350's are relatively cheap and 700R4 would be my choice of a trans. But I like different..:0
As well the box looks to be lower than the cab. I assume some rubber mounts are missing under the box or did someone shave them a little?
Thanks in Advance
suburban99 is offline   Reply With Quote
Old 05-07-2014, 11:27 AM   #2
1963c-10
1963c-10's Avatar
Re: New to the forum, just hauled a '62 c10 fleetside home.
Welcome to the forum and great looking 62.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 05-07-2014, 11:32 AM   #3
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Welcome aboard and sweet 62! I think a 700r4 would be the better choice.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 05-07-2014, 12:10 PM   #4
61K10
61K10's Avatar
welcome--if done correct leave the drivetrain as is. their is nothing with a 2004R trans. plenty strong for a 307. ran one in my 65 elco with a built 350.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 05-07-2014, 12:32 PM   #5
jtrichard
my guess is the bed is down because there is no wood in it
jtrichard is offline   Reply With Quote
Old 05-07-2014, 02:35 PM   #6
65 C20
Welcome to the forum.
This is a great place for info.
Check out the FAQ section.
65 C20 is offline   Reply With Quote
Old 05-07-2014, 02:46 PM   #7
1963c-10
1963c-10's Avatar
Or the forward crossmember is gone.....
And x2 on checking the FAQ's section.....tons of good info.
Old 05-07-2014, 08:24 PM   #8
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
The 200 is a better OD trans than a 700 IMO, the 307 will work until you get her on the road and drive able/safe. Enjoy!!
Oh and welcome!!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-07-2014, 11:13 PM   #9
Softpatch
Softpatch's Avatar
nice truck.! (diamond in the rough)
for starters I would pitch the olds motor.
I'm afraid it will distract you from the love that truck is needed.
Old 307 aftermarket parts are spendy/rare and you wont be happy with the mileage or preformance
sure you could make it run but why ?...
Two words.... Boat Anchor
so if it scabed with a 70's front member does that mean the torsion bars are gone.?
(would like a picture of that)
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
Old 05-07-2014, 11:24 PM   #10
ChefCy
ChefCy's Avatar
welcome!!!!
63 big window lwb bagged and shaved
ChefCy is offline   Reply With Quote
Old 05-08-2014, 12:14 AM   #11
Captainfab
60-66 Nut
I have heard that there were thin rubber pads between the bed cross sills and the frame mounts, but I have never seen them.
What are your plans for the '62?
Old 05-08-2014, 01:16 AM   #12
suburban99
suburban99's Avatar
Truck has a 1978 chev 5 on 5 front cross member and coil springs. No torsion bars. Disc's on the front. Appears to be a 10 bolt rear end as well. Also has power steering box that appears to be stock? I cleaned out the cab and found another power steering pump with hoses....maybe the stock one. Also found patch panels for the lower fenders left and right...
Olds motor and tranny have not been run in this truck...transmission cross member mount is new as I found it in the cab...engine and transmission is out of a 1985 Olds wagon..
Old 05-08-2014, 05:01 AM   #13
Mathew21
Mathew21's Avatar
Welcome, Cool truck.
Mathew21 is offline   Reply With Quote
Old 05-08-2014, 08:46 AM   #14
Jeff La
Welcome and a Nice truck
Jeff La is offline   Reply With Quote
Old 05-08-2014, 10:51 AM   #15
1963c-10
1963c-10's Avatar
yeah....like 3"x3" and 1/2" thick rubber.
Old 05-08-2014, 07:19 PM   #16
Wildman65
Nice Find! Did you get me a double quarter pounder with cheese while you were at McD's? LOL!
Wildman65 is offline   Reply With Quote
Old 05-08-2014, 10:19 PM   #17
suburban99
suburban99's Avatar
Any guesses as to the origin of this rearend? 10 bolt? What's up with the torque arm mounts?
Old 05-09-2014, 10:38 AM   #18
b.sharp
b.sharp's Avatar
That is a "G" body rear end. Usually out of a malibu, el camino etc. nothing different except the ears off the stump and maybe the width.
b.sharp is offline   Reply With Quote
Old 05-15-2014, 12:35 PM   #19
suburban99
suburban99's Avatar
Not much rust so far...
I will pull the engine and rebuild the front end. Control arm bushings look rotted. Most of the boots on the tie rods are torn...frame needs a cleanup.
New balljoints etc.
Probably install a 5.3 or 4.8 depending on budget...and a 700r4.
Anyone made their own stand alone harness for the newer chevy's? Lots of info on Lt1swap.com
Old 05-15-2014, 12:46 PM   #20
1963chevyc20
1963chevyc20's Avatar
welcome to the family!
1963chevyc20 is offline   Reply With Quote
